    Aug 2011
    Ogden, UT
    2002 Pontiac Trans Am
    Anyone converted 06 Corvette transmission to 02 Trans Am?
    Is their a write up on here about that? Ive already bought the main shaft from a GTO, and have the housing t move it over, I just need a write up on how to take apart the vette trans.
    Member 2000dreambird's Avatar
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    I thought the trans in a vette was part of the rear end?
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    If your intend is to do a trans swap go with the T56 MAGNUM. its the T-6060 from the 5th Gen but the tail stock is changed to match 4th Gen's
    Aug 2011
    Ogden, UT
    From what I've gathered is that you remove the housing, and shift rails, then put the internals into your old housing with a GTO Mainshaft, and it will work as an upgraded trans.
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    seems like alot of work to be done when you could just get the t-56 magnum and it holds more HP.... i could be wrong because im not sure of exact numbers.. have you looked into pricing the vette trans?
    Aug 2011
    Ogden, UT
    I bought one for $500, it only had 10K miles. And the GTO Mainshaft was only $200. So it shouldn't be too bad now.
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    hmmmmmm...... do a good write up, id be interested to read up on this..
    Aug 2011
    Ogden, UT
    Alright I will when it's done.
  1. C5 corvette transmission
    By countlamb in forum Corvette
    Last Post: 05-04-2011, 06:20 PM
  2. Question: gto converted
    By burnsxxxls1 in forum GTO
    Last Post: 06-12-2010, 10:37 PM
  3. Converted
    By MatNova in forum New Member Introductions
    Last Post: 06-24-2008, 01:39 PM
  4. converted another one
    By hutch1999 in forum Firebird / WS6
    Last Post: 06-15-2008, 09:59 AM
  5. What ram air box for a 94 converted to 98+
    By gd1996 in forum Firebird / WS6
    Last Post: 03-11-2007, 07:45 PM
