Results 1 to 3 of 3
Thread: ls2 injectors
    Junior Member toysruskid62's Avatar
    pennsylvania
    Cool ls2 injectors
    can anyone tell me what size injectors were used on the ls2 gto?
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Stock injectors on 2005-2006 LS2 V8 equipped C6 Corvette and 2005-2006 LS2 equipped GTO. May also be production injectors on the 2006 LS2 equipped CTS-V as well.
    The LS2 injectors flow 33.9 lbs/hr (4.27 grams/second) at 58 psi (400 kPa) fuel pressure.
    Injector information:
    Bosch part # 0 280 158 049
    GM # 12569113
    USCar connector
    65.2 mm overall length
    52 mm O-ring to O-ring
    4.3 mm tip length
    15 degree spray cone
    4 hole injector
    high impedance
    The USCar connector is not the same type of connector as used on earlier LS1 and other GM V8 engines so these injectors are not compatible with the older vehicles without changing the connectors on the wiring harness. The injectors are also shorter than the LS1 style injectors and the O-ring diameter in the intake manifold is different as well.
    The USCar connector is now also used on several Ford and Chrysler applications.
    Copied and pasted for you. I think its right?
    pennsylvania
    Thumbs up
    thank you for your help ,this information is very useful
  1. F.A.S.T. Injectors??
    By ThunderChicken in forum Internal Engine
    Last Post: 05-31-2011, 09:31 AM
  2. Injectors
    By duweller in forum External Engine
    Last Post: 06-22-2010, 06:27 PM
  3. 42 lb injectors yes or no
    By fast93ta in forum LT1
    Last Post: 02-04-2008, 10:27 AM
  4. Injectors
    By FireRescueWS6 in forum General Help
    Last Post: 01-15-2008, 04:55 PM
  5. FS: 42 lb. Injectors
    By Packy in forum Parts For Sale / Trade
    Last Post: 11-28-2006, 01:06 AM
