Results 1 to 10 of 10
Thread: Injectors
06-21-2010, 05:04 PM #1Junior Member
- May 2010
- Ohio
Black- 2000 T/A WS6
Injectors
I'm looking at getting an ls6 intake and I realized for about a 100 more I can get the 28lb injectors I didn't no if it would be worth it or if I would see a hp gain. I have ory, cat delete, lid, ported tb, no screen, kn filter
06-21-2010, 05:10 PM #2
No, it would not be worth it. If your not maxing out your injectors there is zero reason to swap. Also, even with a slight change in injector, a tune is absolutely necessary.
Buy the intake, skip the injectors unless a data log shows you needing them.
06-21-2010, 05:12 PM #3Just me
- Nov 2006
- Broken Arrow, OK
Not worth it. You would also need to get a tune if you changed injector sizes.
06-22-2010, 01:08 PM #4Junior Member
- May 2010
- Ohio
Black- 2000 T/A WS6
thanks for the help I didn't know if doing more mods down the road would require bigger injectors if so I was going to get them now but the most Ill probably do is bolt ons and a tune
06-22-2010, 02:49 PM #5Junior Member
- May 2010
- Ohio
Black- 2000 T/A WS6
y2k I sent you an email any help would be awesome just trying to identify sock or non stock headers and mystery wire that goes to switch under dash does nothing
http://i922.photobucket.com/albums/a...er/header1.jpg
http://i922.photobucket.com/albums/a...er/header2.jpg
http://i922.photobucket.com/albums/a...ller/wire1.jpg
http://i922.photobucket.com/albums/a...ller/wire2.jpg
06-22-2010, 03:42 PM #6King 0f n00bz
- Jan 2006
- Shepherd, Michigan
they are stockers.
the wires you talk about...everything looks normal, you have your throttle cable, your cruise control cable and your traction control cable. all of which looks normal.
06-22-2010, 03:48 PM #7Junior Member
- May 2010
- Ohio
Black- 2000 T/A WS6
it you look closely there is a wire in the picture on the right side then on the left side it goes to the pcm it kinda runs by itself
06-22-2010, 03:52 PM #8King 0f n00bz
- Jan 2006
hmm well it defiantly isnt stock...id ask the old owner what it went too...a lot of times it goes to a cut out, or a fuel pump kind of set up.
06-22-2010, 03:55 PM #9Junior Member
- May 2010
- Ohio
Black- 2000 T/A WS6
i bought the car from a guy who had 3 cars and never drove this car much the owner before him (original) put it on. The guy I bought it from said he was told it had something to do with the intake
06-22-2010, 06:27 PM #10
F.A.S.T. Injectors??
By ThunderChicken in forum Internal EngineReplies: 7Last Post: 05-31-2011, 09:31 AM -
42 lb injectors yes or no
By fast93ta in forum LT1Replies: 19Last Post: 02-04-2008, 10:27 AM -
Injectors
By FireRescueWS6 in forum General HelpReplies: 1Last Post: 01-15-2008, 04:55 PM -
FS: 42 lb. Injectors
By Packy in forum Parts For Sale / TradeReplies: 7Last Post: 11-28-2006, 01:06 AM -
Injectors
By Phlash_riot in forum External EngineReplies: 10Last Post: 11-06-2006, 06:35 AM
