Results 1 to 20 of 21
Thread: 500 hp mods
03-04-2007, 09:20 PM #1Junior Member
- Mar 2007
- Burnsville,mn
black- 1993 Firebird formula
500 hp mods
hey, i got a 93' bird and am getting a 500hp engine for it. just wondering what i NEED to upgrade and what i SHOULD, and what will happen if i dont. using the car mostly everyday in summer,MN...thanks
...what else should i add to boost power??
03-04-2007, 09:32 PM #2
What exactly do u mean 500 hp engine. I mean w/ that power u will need a good exhaust/ intake setup. (long tube headers / catback exhaust, whatever the best intake setup is for a Lt1)
03-04-2007, 09:38 PM #3Awaiting Activation
- Mar 2006
- LS1 land
yea we need some more details. What kind of engine? Auto or manual? 500rwhp or flywheel. Either way you should do some suspersion mods to put all that power to the ground and prevent it from twisting up your chassis. Subframe connectors at the very minimum.
03-04-2007, 09:48 PM #4Junior Member
- Mar 2007
- Burnsville,mn
ok, its a assembled 383 from precisionengine.comengine, auto tranny, 500 at flywheel
03-04-2007, 09:57 PM #5Awaiting Activation
- Mar 2006
- LS1 land
well im a manual guy, but i know that if you are using a stock A4 that it won't last that long. So i would look into a built trans.
For the suspension i would probably go all out. Things like subframe connectors, lower control arms, panhard rod, torque arms. Then the car should hook pretty good with the right tires.
03-04-2007, 10:00 PM #6Junior Member
- Mar 2007
- Burnsville,mn
are there any kits u can buy to beef up the trany? who has affordable built tranys?
03-04-2007, 10:04 PM #7Awaiting Activation
- Mar 2006
- LS1 land
for the stock A4 most guys put in a shift kit and put a stall in it. Plenty of places make transmissions. I would check out the automatic section of the drivetrain section for better ideas on that. There are member from all over the country and i'm sure there are people in minnesota that have had an A4 built by a local shop.
03-04-2007, 10:13 PM #8Junior Member
- Mar 2007
- Burnsville,mn
thanks a lot, do u think ill need anything else?
03-04-2007, 10:19 PM #9Awaiting Activation
- Mar 2006
- LS1 land
03-04-2007, 10:36 PM #10
12 bolt rear. The stock 10 bolt won't make it. Built tranny as was mentioned.
03-04-2007, 10:41 PM #11Awaiting Activation
- Mar 2006
- LS1 land
03-04-2007, 10:43 PM #12
I wish someone would've told my a4 that when I broke mine with bolt ons.
03-04-2007, 10:46 PM #13Awaiting Activation
- Mar 2006
- LS1 land
03-04-2007, 10:50 PM #14
03-04-2007, 10:55 PM #15Awaiting Activation
- Mar 2006
- LS1 land
03-05-2007, 11:09 AM #16Junior Member
- Mar 2007
- Burnsville,mn
how much are the stock trannys able to handle with a shift kit and converter?
03-05-2007, 11:14 AM #17
Definately a beefed-up tranny and built rear-end. Stock rears can break under stock power. Possibly a new aluminum driveshaft as well. Suspension also if you want to get all that power to the ground.
03-05-2007, 11:19 AM #18Senior Member
- Sep 2005
- rochester,ny
pewter- 2001 z28 lingenfelter 383
his stock rear end COULD last a long ass time if he dosnt beat on the car and or put slicks on it.........im still on the stock rear end and its quiet as can be...i dont drag the car either though
03-05-2007, 11:32 AM #19
You're right, it COULD last a while. But it won't survive the first few hard launches at the track. What good's a stall if you don't use it?
03-05-2007, 11:36 AM #20Junior Member
- Mar 2007
- Burnsville,mn
honestly, dont go to track much, mostly highway, will that make a difference?
15 Cheap Mods - 15 No-Buck And Low-Buck Mods
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 03-05-2012, 04:20 PM -
2004 Cobra w/mods Vs. R34 Skyline w/mods
By Packy in forum Kill StoriesReplies: 88Last Post: 08-31-2009, 06:26 PM -
Question: Mods
By repeter in forum GTOReplies: 1Last Post: 02-15-2009, 01:00 PM -
Question: doing mods
By cramn4903 in forum Camaro / SSReplies: 9Last Post: 02-09-2009, 05:18 PM -
$2000 on suspension mods or on motor mods??
By greatwhiteZ28 in forum Suspension and HandlingReplies: 6Last Post: 09-27-2007, 06:04 AM
