Results 1 to 10 of 10
Thread: doing mods
01-19-2009, 06:19 PM #1Junior Member
- Jun 2006
- Amery, Wisconsin
Hugger Orange- 1999 Chevy Camaro Z28
doing mods
Hey everyone. I'm finally going to start doing stuff to my car, but I have some questions first. The only thing i have done to it is a CAI and magnaflow exhaust. I plan on getting pacesetter longtubes because i have heard nothing but good things from people on here, and they are relatively cheap. I want to get gears... I hear a lot of people get 3.73s as well as 4.10s. I know 4.10s are more of a drag set up.. but i'm still not sure what would be best.. also does someone know of a good place to purchase them? Also i have an A4 so i was thinking of a stall. How is hookup on street tires with say.. a 3600 stall? Should I get a torque arm as well? I also wonder how the stall works... does it launch every single time you take off.. or do you have to engage it or press a button to make it launch? Sorry this is so long... just trying to do things the right way, and I know many people on here know what they're talking about. So anything will help.. thanks!
01-22-2009, 11:28 AM #2Member
- Sep 2008
- Minnesota
Pewter- 2001 Z28
I have the pacesetter longtubes and they are ok, but they bang on the floor boards otherwise they are really nice, I want to get gears too probably 3.42s though.
01-22-2009, 12:34 PM #3Member
- Apr 2008
- Tucson
Psycho Therapist- I take "the" out of
If you get some aftermarket motor mounts it will solve the problem of the lontubes banging on the floor board. they are like 50-90 dollars for the pair, and if you know what your doing, they may just take a short time to install.
Check the sponsors on the side, or a local speed shop.
01-22-2009, 01:26 PM #4
well us a4 guys dont have enough gears to where we would be hardly affected with 4.10s like the m6 guys so for mild play a solid choice is 3.73 so we wouldnt lose too much up top and gain enough down low to where it would be enjoyable and competitive. also its not a noticeable damper on gas mileage. unless of course you nitpick and are trying to keep that 1-2 mpg. a 3600 stall is what i am planning for aswell. it will not launch every time you move from a stop. im pretty sure it revs a bit higher but still will roll while in gear and act normal while driving and/or coasting. but when you floor it the rpms will spin freely up to close to specified stall speed and then the torque will be applied
. so it doesnt change daily driving much from what ive seen and heard. but before applying all that torque to the tranny and frame. i would get some subframe connecters, a shift kit(transgo hd2 for the 4l60e is highly recommended), and a tranny cooler. just a little insurance. i would watch out for the tranny though. a stock 4l60e is a solid tranny for a little play but not real good for competition so just be wary.
01-22-2009, 01:37 PM #5Exalted Cyclops
- Feb 2007
- San Diego, CA
3600 stall + street tires + full throttle = slip and slide......
Normal driving = 3k rpm thru 1st, 2nd, 3rd and OD. Mine is set so the clutch engages at 40mph at normal throttle. I have a Fuddle 3400. I also have 3.73 gears.
I'd look into some SFC's so your car doesn't turn into a pretzel.
Even at 43k miles my A4 was showing some wear. I had it rebuilt to Stage 3 specs (Beast stainless steel sun shell, Raybestos clutches, torque management delete and a tranny shift kit + a few other mods that my tranny guy keeps a secret - his car runs 11.70's so I think he knows what he's doing) and I added a tranny cooler.
Last time at the track I ran a 12.66 @ 107+ with a 1.69 60'. This was with Nitto 555r's at 24 lbs.Last edited by 67CamaroRSSS; 01-22-2009 at 01:47 PM.
01-22-2009, 06:25 PM #6Awaiting Activation
- Jun 2008
- Decatur Al
NBM- 99 Z28
01-23-2009, 10:39 AM #7Junior Member
- Jun 2006
- Amery, Wisconsin
thanks for the replies guys.. your help is much appreciated.
01-26-2009, 08:54 AM #8
02-09-2009, 01:10 PM #9Junior Member
- May 2008
- texas
metallic pewter, red- 2002 Z28, 1972 Z28
So going from 2.73 to 3.73 how much top end would I lose?
02-09-2009, 05:18 PM #10
15 Cheap Mods - 15 No-Buck And Low-Buck Mods
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 03-05-2012, 04:20 PM -
2004 Cobra w/mods Vs. R34 Skyline w/mods
By Packy in forum Kill StoriesReplies: 88Last Post: 08-31-2009, 06:26 PM -
Mods
By thearborbarber in forum Request and FeedbackReplies: 1Last Post: 02-20-2009, 04:56 PM -
Question: Mods
By repeter in forum GTOReplies: 1Last Post: 02-15-2009, 01:00 PM -
$2000 on suspension mods or on motor mods??
By greatwhiteZ28 in forum Suspension and HandlingReplies: 6Last Post: 09-27-2007, 06:04 AM
