Results 1 to 2 of 2
Thread: LS1 sensor wiring details
02-27-2007, 11:46 PM #1Junior Member
- Feb 2007
- New Zealand
Hi Guys,
Over here in New Zealand I am involed in a project fitting an 5.7L (350 cu) LS1 engine into a 95 Camaro, to be used in this years Dunlop Targa (5 day long tour racing against the clock on closed roads).
The LS1 is from a 2002 australian Holden Comodore (you get the two door coupe versions rebadged as a pontiac)
Any way, I am building the ecu system for the engine, based on a megasquirt MS1 system, and would like some information on the sensor wiring for the cam and crank, as well as the quad coils.
The crank and cam are both a 3 wire and I believe are 5v powered, the coils are 12v powered, but controlled with a 5 volt signal ?
Any diagrams , pictures or help will be greatly apreciated.
At the end of the day I paln to have a ecu system that is plug'n'play with the LS1 engine, for guys doing engine conversions (the LS1 is becomming a popular swap over here
Thanks in advance
Mathew
03-01-2007, 01:21 PM #2Junior Member
- Feb 2007
- New Zealand
anyone ?
Question: O2 Sensor Wiring Harness help
By herculesrider1 in forum Firebird / WS6Replies: 14Last Post: 08-07-2013, 07:24 PM -
Different knock sensor wiring
By Dewman in forum General HelpReplies: 4Last Post: 03-03-2009, 03:26 AM -
will i need 02 sensor wiring extensions?
By bgable in forum External EngineReplies: 24Last Post: 09-29-2007, 05:35 PM -
Knock Sensor Wiring Gone Bad??? Please Read
By TurdsOfMayhem in forum Firebird / WS6Replies: 6Last Post: 08-20-2007, 07:45 AM -
O2 sensor wiring...
By SunsetZ in forum External EngineReplies: 7Last Post: 06-19-2006, 04:11 AM
