Results 1 to 10 of 10
    Member BKHgto04's Avatar
    Feb 2007
    Alabama
    2004 GTO
    Newbie Needs Help With Tire Wear Problem
    What's up guys,
    I am having a problem with tire wear on the front of my 04 GTO. The tires that are on it now are Fuzion ZR1's. Here recently the car started getting alot of road noise. I rotated the tires and it is not as bad but it is still there. It is probably the tires that are on it but just wanted to see if anybody else has had this problem.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Probaly the strut rub problem people are facing. I beleive with a little more positive camber will fix the problem.
    Sarge can tell you for sure. I know he corrected this problem.
    Feb 2007
    Alabama
    2004 GTO
    Actually it acts like a strut problem. I checked for strut rub and I don't see any problem. The tire wear is not even though.
    Has anybody tried these Fuzion ZR1's before?
    Florida
    1999 TA WS.6
    Take it to the dealer. If it is a strut rub problem.... it will be covered under warranty.
    Feb 2007
    Alabama
    2004 GTO
    I checked for strut rub. It is not rubbing at all
    After a few more miles look at the inside 1" or so of your fronts. I would bet money you have strutt rub. Extremely common on these cars.
    Member Tide's Avatar
    Southeast
    Nothing special
    Nothing special
    The excessive tire noise on my developed after the strut 'fix', and I had excessive wear on the inside as well. I would strongly suggest checking the tires for areas where the steel belts could possibly have worn through.
    Feb 2007
    Alabama
    2004 GTO
    I have checked for the strut rub problem and everything seems to be ok. I am really hoping that the problem is the tires that are on it right now. I am going to go back to the g-force and see if that fixes it. I really appreciate the help everybody.
    Junior Member ls1hoon's Avatar
    melbourne, australia
    2002 Holden Commodore SS
    is it the rear tyres wearing or front?
    Feb 2007
    Alabama
    2004 GTO
    The front tires are wearing. They are kinda wearing in a wavy pattern,just on the front,on both sides. The belts don't seem to be separating either. I just rotated the tires about a week ago and it helped at first,but it is starting to do it again on the tires that were on the rear.
  1. Does this looks like out of the normal tire wear?
    By JayTA98 in forum Wheels and Tires
    Last Post: 05-22-2013, 05:29 AM
  2. tire wear
    By cobra12345 in forum General Help
    Last Post: 08-12-2007, 02:57 PM
  3. Tire Wear
    By jroc in forum Firebird / WS6
    Last Post: 12-30-2006, 04:17 PM
  4. Uneven tire wear on rear tire??
    By renzo in forum Wheels and Tires
    Last Post: 11-20-2006, 04:30 PM
  5. Tire Wear
    By SailorZ28 in forum Wheels and Tires
    Last Post: 03-22-2006, 05:33 PM
