Results 1 to 19 of 19
Thread: Line Locks
    a.k.a. one-tone zbizkit's Avatar
    Burlington, Ky
    95 z28, 05 Altima
    Line Locks
    A got a couple of questions in regard to line locks. First which one is better. I see that SLP and hurst both make one. The only difference in the LED light and push button activator of the Hurst.
    Second will the line lock affect you ABS. if so what problems does it cause and how can you fix it?
    Where is the best place to mount the switch? and which activators/switch type do you use. I really don't like the toggle switch.
    Thanks,
    Junior Member Knight_Rider's Avatar
    South Houston, Texas
    2002 Camaro Z28
    I purchased the Hurst Roll Control kit over @ Thunder Racing. It comes with everything you need (Hurst solenoid, push-button lighted switch, pre-bent brake lines and the wiring harness.)
    It works great and I haven't had any issues with the ABS thusfar, though it doesn't get activated that often. The ABS, that is.
    As far as the installation location, I put it in the center ashtray. It's out of the way so it won't accidentally be activated. Some people install it in the center of the dash beside the ASR switch, but to each his own. Good Luck.
    2002 Camaro Z28
    Black/Black w/T-tops
    340 RWHP / 367 RWTQ
    13.052 @ 108.22 2.08 60'
    Marylandistan
    2001 Trans Am (sold)
    Wont affect your ABS.
    i make cars slower s99ta's Avatar
    Iowa
    i have the slp one every thing works fine put the switch in the ash tray
    Member '99 SLP#24's Avatar
    Norman, Oklahoma
    1999 Camaro SS #24
    98 Corvette-99 Camaro SS
    is it typical for the brakes to feel spongy after a line lock install or do I still have air in my brake lines?
    Norman, Oklahoma
    1999 Camaro SS #24
    Anyone know got any info on this?
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by '99 SLP#24 View Post
    You probably have air in the lines, the kit shouldn't affect the feel of the pedal.
    Bleed it from the front and back until only fluid comes out.
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    Quote Originally Posted by Wesman View Post
    You start at the farthest point and work to the closest. You bleed a system from the right rear, left rear, right front, and then left front.
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by BIG D's SS View Post
    Yea I know, I didn't mean to imply any order in which to do it. I meant bleed the whole system, front/back/left/right, not just one wheel.
    Commerce Ga
    Black, Blue
    Oh ok.
    Norman, Oklahoma
    1999 Camaro SS #24
    Thanks guys, one of the bleeder valves is starting to strip out whats the best replacement GM parts?
    Commerce Ga
    Black, Blue
    Just get a bleeder that matches up. There is nothing special about them. Same thread count and size is all that you need to worry aobut.
    Norman, Oklahoma
    1999 Camaro SS #24
    ok thanks!
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    dang it. and here i've been doing it wrong, for years. i do the opposite.
    Commerce Ga
    Black, Blue
    orlando, fl
    2014 camaro 2ss/rs
    honestly, it doesn't matter which way you do it, on our cars. i do it front left to right rear. this way you aren't pulling old fluid into the new fluid by starting from the rear first. just my theory. i do know some cars with ABS have a specific way the manufacturer wants it done. i have my brake bleeding sequence book at work. maybe, i'll peruse it tomorrow.
    Commerce Ga
    Black, Blue
    Just a rule of thumb that we do here at Year One is start farthest and move closest. I have done it several ways, but I have had good luck this way so I want change.
    orlando, fl
    2014 camaro 2ss/rs
    yeah, i heard it back over 20 years ago to do it the right rear to left front way. again, it's just a preference.
    Commerce Ga
    Black, Blue
    I just stay with what I know works.
  1. T top locks..
    By pbguy357 in forum Firebird / WS6
    Last Post: 11-10-2011, 07:01 PM
  2. Line Locks
    By jetaws6 in forum Manual Transmission
    Last Post: 11-26-2009, 02:05 PM
  3. Line lock/ brake line ?
    By 2001z in forum Suspension and Handling
    Last Post: 04-01-2007, 05:42 AM
  4. Line Locks
    By hllywd in forum Drag Racing
    Last Post: 01-03-2006, 11:35 PM
