Results 1 to 11 of 11
Thread: Line Locks
    Member jetaws6's Avatar
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    Line Locks
    Will line locks work on the stock t56 trans or even a manual trans. I came across them on ws6store.com and it got me thinking. Also how hard are they to install?
    A line lock is used to maintain pressure on the front brakes and allows for easier burnouts and staging. There are kits that fit our cars and come with pre-bent lines. You mount the solenoid, install two new brake lines, and wire it up to a power source and switch. After installation, the brakes will need to be bled. Here's a shortcut to a thread I started a few months ago: http://www.ls1.com/forums/showthread.php?t=119695
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    So I guess they will work on a manual trans
    Member Skippy's Avatar
    Oct 2009
    Perkins, OK
    04 Pontiac GTO
    Yes they will, the transmission has nothing to do with the braking system
    Ashes to ashes and dust to dust, if it wasn't for fords our tools would rust
    Quote Originally Posted by jetaws6 View Post
    Yes
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Yes they will work fine. Forget ws6store. Mark at kyspeed.com will get you a great deal and is a site sponsor.
    yep....get with mark at kyspeed. You'll love having a line lock if you go to the track much.
    I'll add another question to this: Except for the F-body specific SLP line lock, every other brand in the catalogue states that they are "not for use on ABS equipped vehicles". This includes TCI, Biondo, and Hurst. The Summit brand does not accept metric fittings and B&M simply does not specify.
    I do not see any real difference between them -- anyone know why they are designated as non-ABS? If I were going to mount the line lock between the wheelhouse and wheelwell liner, I wouldn't need the pre-bent lines that come with the SLP kit, so the extra expense really is not justified.
    Member marksls1ta's Avatar
    pikeville, kentucky
    1998 trans am
    I can get you any kit you would like at a good deal. The SLP is a hurst with lines. That is what I have sold in the past and what I use on mine.
    I am thinking about a BLACK FRIDAY SALE on them.
    Mark
    Mark -- any idea on the ABS vs. non-ABS?
    pikeville, kentucky
    1998 trans am
    Not really only thing i can figure is that SLP done some loop jumping and got it apporved thru GM or something.
    Mark
  1. T top locks..
    By pbguy357 in forum Firebird / WS6
    Last Post: 11-10-2011, 07:01 PM
  2. Line Locks
    By zbizkit in forum Manual Transmission
    Last Post: 04-25-2007, 01:53 PM
  3. Line lock/ brake line ?
    By 2001z in forum Suspension and Handling
    Last Post: 04-01-2007, 05:42 AM
  4. Line Locks
    By hllywd in forum Drag Racing
    Last Post: 01-03-2006, 11:35 PM
