Results 1 to 20 of 25
    Member barryTA's Avatar
    Aug 2006
    ARIZONA
    2001 trans am
    koni sa or koni da
    I have decided to go with koni shocks. Dont know if I should go with the
    single adjustable of the double adjustable. can any one tell me the benefits
    of having the DA over the SA? Also is the DA able to go to stiffer setings
    then the SA koni's ?
    THANKS!!!
    Aug 2006
    ARIZONA
    2001 trans am
    not even one person responded to my thread come on!!
    The DA's have an additional adjustment (compression?) than the SA's.
    It really makes for allot more setting capabilities (over 1000?) which can get technical almost too technical so I went for the SA's.
    Also with the SA's they have two perches so you can set the springs at two heights. They adjustments are enough for me front and back (4th gen)
    It is up to you but you will be very happy with either dampers.
    Aug 2006
    ARIZONA
    2001 trans am
    also i got flow tech long tube headers and umi 3 point sub frame's do you think i whould have enuff room for 1 1/2'' lowering springs?
    Thanks for your help
    Aslong as you have 'stiff' enough springs you should be ok. But some LT's really hang low so you will have to judge that for yourself as you do not want to be scraping everything as you have a street car.
    Reasearch it some more but try a search on 'Strano Springs' on here and LS1tech as there are some posts/threads with pictures so you can make an educated decision.
    Aug 2006
    ARIZONA
    2001 trans am
    Thanks alot man!!
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    unless you are a very serious road-racer or autox-er, there ain't much of an advantage going to a DA over an SA
    The difference between both of them is that in the DA, you set up both compression and rebound independently on the DA, while on the SA, you set them together on a "general" setting.
    Also note that the more adjustability you have allows for more room to screw it up... lol
    I love my DAs... but if i'd redo it again, i'd get SA for the rear, not DA allround... and i race quite a bit.
    Eugenio_SS
    Berkeley, CA
    2000 Camaro SS #3574 A4
    what kind of a difference do the Konis make of stock shocks?
    San DEEEE Eggo
    teal
    99 Z28 with an SS complex
    I will be finding out about the SA's in about ten days, i'm not home right now but i am havin them installed, so when i get back the car will be ready then i'll post. SA's are alot cheaper than the DA's, only go DA's if you are hardcore.
    Was not worth it for me.
    Member rickssz's Avatar
    Feb 2006
    pgh
    What kind of rebound or extension setting do the SA come with standard ie soft semi-soft med semi-firm firm set for cornering braking launching bumps rough surfaces???????????? Since they dont adjust I need to know since I wanted to use them on the street and 1/4 launches so the preset bump or compression shouldnt be stiff.
    Jun 2002
    Montreal, CANADA
    triple-black
    same as going from a Reliant K into a Viper.
    Jun 2002
    Montreal, CANADA
    triple-black
    Quote Originally Posted by rickssz View Post
    you can still adjust them... it's just that both settings are correlated, instead of being independent. ie, in a DA, you can increase the compression by 1 click and decrease the rebound by 1 cilck.
    On a SA, you'll have to chose from leaving in current position, increase both or decrease both... so unless you are hardcore... not really worthed.
    Yet, if anything, it's worthed to get it in the front and go w/ SA in the rear. DA in the rear aren't worthed.
    Feb 2006
    pgh
    So the SA are good for the street but a tradeoff or compromise for Drag racing like using adjustable 50/50 on the front?
    No trade off esp for the drags.
    Like Eugenio said the difference is like a K-car compared to a Viper. Buy the SA's you cannot go wrong with Koni!
    Feb 2006
    pgh
    So if you wanted to stiffen the rebound you would have to stiffen the bump too?
    Jun 2002
    Montreal, CANADA
    triple-black
    on the SA, yes... on the DA, they are 2 independent settings.
    ie, SA = single adjustable; DA = double adjustable.
    think about the first time you got laid; it rocked right? Now picture it was with jenna jameson and her 10 hottest girlfriends....it's kinda like that.
    Berkeley, CA
    hahaha, I need them!
    Best way to describe the difference yet!
    Feb 2006
    pgh
    Irregardless of what was just said it seems the rear should be DA not SA.
  1. Koni 4/3 Set
    By See Me In My GTP in forum Suspension and Handling
    Last Post: 03-06-2010, 09:57 PM
  2. Koni? which set?
    By NetrixTardis in forum Suspension and Handling
    Last Post: 08-26-2008, 06:38 PM
  3. Qa1 Vs Koni
    By GUSHER in forum Suspension and Handling
    Last Post: 06-11-2007, 03:07 PM
  4. Are these Koni SA's?
    By mindreaper in forum Suspension and Handling
    Last Post: 11-22-2006, 03:11 PM
  5. QA1 SA's vs Koni SA's
    By 5.7 Reasons in forum Suspension and Handling
    Last Post: 02-09-2006, 08:46 AM
