Results 1 to 10 of 10
    Virginia
    2000 Trans Am
    QA1 SA's vs Koni SA's
    I'm in the market to purchase a set of new shocks and narrowed my choices to either the QA1 SA's or the Koni SA's. Right now I'm running Ground Control Coil-Overs. I was wondering if anyone has ever compared the two, and which one is the better setup for all around performance.
    if you go to BMR's site, they mention somewhere that their QA1's are pretty much better off for tracking, the koni's are better "all around" as you say. www.bmrfabrication.com
    Virginia
    2000 Trans Am
    Thanks for the info. I was hoping that the qa1's were the better choice because they are less expensive. I guess its koni's for me.
    ick, i'm in the same boat, hoss. the other thread is comparing KYBs to SLP Bilistiens..might be something to consider
    Virginia
    2000 Trans Am
    I know this is going to be like comparing apples to oranges but my brother who had a 2003 Sunfire was running KYB's with Ground Controls, he lowered it about 3 inches. He had them on for about a year (approx. 14,000miles) until one of them blew. I'm not sure if he just recieved a bad one or what. I also know that ride height also affects the wear and tear on a shock, so that might be the blame. I'm not saying they are bad or nothing like that, I'm just a little iffy about running those with ground controls.
    and i bet the warrenty kicked at 14k too, huh?
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    Koni's are much better choice...
    Eugenio_SS
    Junior Member hotpart.com's Avatar
    Paso Robles CA
    The qa-1's are not a very good shock unless you are drag racing only. They are oil filled shock which will work great until you heat them up. Once they start getting hot the oil begins to thin, they start to fade and loose the ability to control whatever spring combination you are using. If you are looking for a good solid performing shock stick with the Koni's, Bilstein's, or Tokico's.
    Good Luck,
    Brian Croutcher
    J&M Products
    [email protected]
    hotpart.com
    805-239-1558
    Quote Originally Posted by Eugenio_SS
    By far the better choice...
    Virginia
    2000 Trans Am
    Quote Originally Posted by dipherentdesign
    The shocks come with a "limited lifetime warranty" so I guess they will repair or replace the shock. But that's such a pain, having to keep swaping your shocks out while you send the other one out for repairs.
  1. Koni 4/3 Set
    By See Me In My GTP in forum Suspension and Handling
    Last Post: 03-06-2010, 09:57 PM
  2. Koni? which set?
    By NetrixTardis in forum Suspension and Handling
    Last Post: 08-26-2008, 06:38 PM
  3. Qa1 Vs Koni
    By GUSHER in forum Suspension and Handling
    Last Post: 06-11-2007, 03:07 PM
  4. koni sa or koni da
    By barryTA in forum Suspension and Handling
    Last Post: 03-08-2007, 04:08 PM
  5. Are these Koni SA's?
    By mindreaper in forum Suspension and Handling
    Last Post: 11-22-2006, 03:11 PM
