    rique71
    tampa fl.
    1998 z28
    will this work.....
    http://cgi.ebay.com/ebaymotors/ws/eB...7036&rd=1&rd=1
    will this work on my 98 z28 a4 stock rear end 2.73 gears?
    rique71
    tampa fl.
    1998 z28
    anyone?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    it will fit in, yes. problem is, he doesn't specify what gear came off of it to determine if it is a 2 series carrier (which you need if you are keeping the 2.73 gears), or a 3 series carrier (if you are going to go to 3.08 or higher numerical gears, then it is the correct choice).
    rique71
    tampa fl.
    1998 z28
    ok thanks i will look into that
    In the corn field
    It looks like a 3 series carrier to me. I have my 2 series on the bench and it looks a little different then the one pictured. My looks like it has more space between the ring gear flange and the window in the diff where the springs are visible.
    doylestown, Pa
    SILVER
    2004 CTS-V
    I wouldn't trust that it works! He doesn't even mention what brand it is!
    In the corn field
    It can't work unless he gets a spacer for his 2.73 gear. It says in the descripion it's a 3 series carrier. Maybe he's going to get new gears.
    rique71
    tampa fl.
    1998 z28
    yeah i am going to get new gears (3.42) i went to see the part , the ebay seller is actually located a few miles from my home. and he told me he can put it on for me when i get the gears for $250 . and if it doesnt fit he will refund me my money
  1. Is recall work warranty work?
    By RealLiveMD in forum Almost Anything Goes
    Last Post: 04-30-2010, 05:20 PM
  2. anyone else work a shitty shift at work
    By issues in forum Almost Anything Goes
    Last Post: 08-18-2008, 01:17 PM
  3. work
    By third_shift|studios in forum Multimedia Section
    Last Post: 03-21-2007, 09:22 PM
  4. *Will this work?
    By 94 Formula in forum Nitrous
    Last Post: 07-09-2006, 12:10 PM
  5. Does the Air Box cut out really work?
    By Jason Leighter in forum General Help
    Last Post: 06-15-2006, 02:53 PM
