Results 1 to 2 of 2
    Member 94 Formula's Avatar
    La Mesa
    M3 SMG 350HP
    *Will this work?
    I Just purchased a 99z28 with the below mods and I would like to know if a NX Maf kit would work well with the setup I have? What type of power should I expect from a 100 shot wet on top of my Heads & Cam.
    99Z28 M6
    Stage II 6.0L Heads
    MMS 233/233/578/113LSA
    Every bolt-on and the car makes. 427rwhp & 401rwtq right now with 39,000 miles on the clock.
    Thanks for any info!
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    nitrous kits work with whatever you have. one thing you didn't list was whether or not it had an upgraded fuel pump.
  1. Is recall work warranty work?
    By RealLiveMD in forum Almost Anything Goes
    Last Post: 04-30-2010, 05:20 PM
  2. anyone else work a shitty shift at work
    By issues in forum Almost Anything Goes
    Last Post: 08-18-2008, 01:17 PM
  3. work
    By third_shift|studios in forum Multimedia Section
    Last Post: 03-21-2007, 09:22 PM
  4. will this work.....
    By dag711 in forum Drivetrain
    Last Post: 02-20-2007, 01:09 PM
  5. Does the Air Box cut out really work?
    By Jason Leighter in forum General Help
    Last Post: 06-15-2006, 02:53 PM
