Thread: 383 Setups and Numbers????
02-13-2007, 04:51 PM #1
I just built a 383 and am still breaking it in...150 miles so far. I know it's a little late to be considering a different cam, but I was told the cam I put in it was a little small and I wouldn't really reap the benefits of the motor. Who out there has a 383, what #s are you putting down, and what mods do you have to make that HP? LG said they'd like me to get 1K on the motor before tuning, so I have no idea what I'll put down...I'm hoping at for 425 rwhp or better. Sig is below...
__________________
98TA/2006 LSX Block/Eagle 4.0" Stroker Crank/6.125 Eagle 4340 H Beam Rods/Mahle Forged Pistons/Mahle File to fit Plasma Moly Piston Rings/LS6 High Flow Oil Pump/Patriot Stage 2 LS6 heads/Harland Sharp shaft mount aluminum roller rockers/SLP Lid/Free ram air mod/Smooth Bellowes/160 stat/Taylor 10.4mm wires/Comp 232/234 595/598 112 lsa/patriot gold springs/chrome-moly push rods/LS1 Edit(old tune)/LS6 intake and p&p throttle body/Spec3 clutch/Fidenza aluminum flywheel/Motive 4.10/MAC mid-lengths/MAC ORY/SLP catback
02-14-2007, 02:15 PM #2
I have a mild 383.
Here are the internals:
TEA 5.3 1.5 heads with 2.05 intake 1.60 exhaust
Forged Dimond pistons approximate compression 11.2 to 1 with current heads
Forged Eagle Rods 6.125 inch
Forged Eagle Crank
Rotating assembly balanced by Evans Automotive
Comp Cams XER 612/244/112 +4
Rollmaster Timing chain
TSP oil pump
Externals:
Hooker headers
BorlaMouth
LS6 intake
ASP pulley
She put down 456/450 with nice flat curves... I think a FAST intake and better exhaust could get me in the 475/460 range, which is pretty good for what I've spent.
02-28-2007, 07:01 PM #3
Any others??? I have about 650 on the odometer now and plan on having it tuned this weekend...
03-01-2007, 02:17 PM #4
Heh. You are never going to hook on the street with those 4.10s... Let me know what she puts down. Ben
03-01-2007, 02:55 PM #5
Tell me about it...I'm getting sideways at 60-65 and dropping to 3rd. I'm running Cooper 245/50/16 now, but I was wondering if the BF Drag radials would do OK
Oh, and I found out I'll have to wait till next weekend for the tune since the shop's tuner is only there every other Saturday.Last edited by greenvilleTA; 03-01-2007 at 02:57 PM. Reason: Update
03-01-2007, 03:31 PM #6
I think you better have money set aside for a 12-bolt if you put DRs on her. Lack of traction is your friend because the first time you dead-hook, you'll probaly turn the 10-bolt into confetti...
Stealth Box Setups
By fbird777 in forum Stereo and ElectronicsReplies: 17Last Post: 11-14-2007, 01:34 PM -
Tr230 dyno numbers 98 heads=bad numbers?
By phoenix1987 in forum Dyno InformationReplies: 7Last Post: 09-11-2007, 08:33 AM -
Intake/TB Setups
By 98formy in forum External EngineReplies: 3Last Post: 03-09-2007, 05:36 PM -
pics of setups
By 99kamarokid in forum NitrousReplies: 26Last Post: 07-29-2006, 09:45 AM -
Changing setups
By Snake Eater in forum External EngineReplies: 1Last Post: 01-31-2006, 07:25 PM
