Results 1 to 15 of 15
Thread: rough idle?
    1 01ls1ws6's Avatar
    houston tx
    pewter
    01 ws6
    rough idle?
    at an idle my trans am has kinda a rough idle. what do yall think it could be? fuel injectors maybe?
    Senior Member Wheeler99WS6's Avatar
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    are you stock? If not post up what mods you have, and how long has this been happening, is it only at idle, if you give a little gas does it go away, what rpm do you idle at? automatic or Manual?
    1 01ls1ws6's Avatar
    houston tx
    pewter
    01 ws6
    ya im stock except for an slp lid and t stat its been happening for about a month, mine idles at like 500-600 rpm and it does seem to go away when you give it gas, its an a4
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    How many miles on your car? could quite possibly dirty injectors.
    someday joejenkinsglass's Avatar
    Iowa
    green
    98 formula
    seems like 500-600 is a little low it does sound like the inj may be dirty
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    My car is A4 also and it idles at 500-600 also while in drive. I think the M6 is programmed to idle a little faster but not for sure. but sounds as if perhaps some seafoam could cure this guys problem. hard to tell for sure with no codes being thrown.
    Iowa
    green
    98 formula
    mine is also an a4 I rarely drive it but I remember it being around 700 same as my wifes 6m who knows I have heard the guages are for reference only
    Quote Originally Posted by Wheeler99WS6 View Post
    1 01ls1ws6's Avatar
    houston tx
    pewter
    01 ws6
    Sea Foam Whats That? A Fuel Additive, Will It Harm The O2 Sensors Or My Cats? I Just Put Some New Spark Plugs In And It Helped A Little
    Iowa
    green
    98 formula
    its an upper intake cleaner usually it gets sucked into the engine at a high idle how are your wires and coil packs? I have heard good things about sea foam but have not tried it
    Quote Originally Posted by 01ls1ws6 View Post
    1 01ls1ws6's Avatar
    houston tx
    pewter
    01 ws6
    i have msd 8.5 wires that are only a month old but im not sure about the coil packs. We the seafoam damage my spark plugs?
    Houston, TX
    2002 Firebird Formula
    Is your throttle body dirty? That will make the vehicle idle rough as well, I cleaned mine, and my rough idle went away entirely. I just bought carb cleaner, took of the airbox lid and bellows, and spray some in there and take a soft cloth and wipe it out, spray on the springs and open and close the throttle body....
    I have had like 3 fuel injectors fail in my car since I got it new, so also could be a fuel injector obviously, but you can easily inspect your throttle body yourself.
    Have you changed the fuel filter lately?
    Painted manta stripe
    IL
    06 HD Softail
    1998 Trans Am m6
    STP fuel inj. cleaner, it helped my 93' lt1 when i had the same problem
    Junior Member svt_bolt_99's Avatar
    Aug 2006
    Woodlands Texas
    black / white
    '99 Lightning / '01 WS6
    not trying to hijack anyones thread here, but I also have the same problem. I have changed plugs, wires. My only mod is a MTI lid....my idle is around 500 also ('01 WS6 - 52k miles) and it's rough....
    car smart member
    aug, ga
    2000 / TA ...lol
    You first need to find out if you have any leaks in the intake of makybe any of the intake hoses. Get a can of carb cleaner or fuel injector cleaner and spray over the edges of the intake and hoses and listen for a change in idle. If it does change in idle then you have a leak of some sort. Last time I had an issue, I had a hole in my PCV tube right next to the throttle body. I replaced it with a piece of coolant hoses and that was that.
  1. Rough Idle
    By thacher2189 in forum LT1
    Last Post: 02-19-2012, 02:04 PM
  2. Help: Rough Idle
    By 1WickedWS6 in forum GM Trucks
    Last Post: 01-04-2012, 07:16 AM
  3. Help: intermittant rough idle, off idle hesitation
    By Matto4785 in forum General Help
    Last Post: 09-21-2009, 05:12 AM
  4. Help: rough idle
    By RLamas in forum Firebird / WS6
    Last Post: 05-01-2009, 04:59 PM
  5. C5 Rough Idle
    By BlkNBlkC5 in forum Corvette
    Last Post: 04-14-2007, 06:42 PM
