    houston
    What is the diffrence between master/slave cylinder
    Trying to figure out what I need to replace and I have had people tell me that its the slave and others its the master. Would like to keep this cheap as possible. Last week sometimes like after a red light it would be really hard to get back in gear and then with the clutch all the way in it would seem like the car wanted to go forward and then the clutch wouldnt come all the way back up and would just stick there. Then last night I went out before i even started the car it had no resistance and stuck right to the floor and it cant be put inot gear. So now it sticks to the floor and cant be put into gear...can anyone help me with a diagnoisis.
    Ive searched and some say master some say slave and some say pressure plate but I would like if someone could narrow it down a little...
    If your pedal is staying on the floor. It is your master cylinder.
    houston
    ok so from what ive heard the master cylinder is a much easier fix than the slave...is there a certain master cylinder you would suggest or just get OEM. can i get a new one at autozone or napa or will they be refubished.
    Any parts store should have rebuilt units fairly inexpensive.
    S. Florida
    98 Formula /93 Z28
    Could be the slave or the master. MIne did the same thing and it was the slave. The master is a much easier install though.
    houston
    well cheapest master i found is 70. i guess i will do that one myself and hope for the best. if that doesnt work im going to have to fork up 80 for the slave plus prob around 100 to get it installed since thats more than i can handle...sucks
    old timer blue02Z's Avatar
    2002 Z28
    do the drill mod when you get the new master, it helps.
    metro Detroit area
    Before you buy anything do a proper bleed of the hydraulic reservoir and be sure the fluid is fresh.
    houston
    to bleed the hydraulic resivour you open the hex nut on the transmission and press the clutch in then close it and repeat over and over right?
  1. Question: What slave/master cylinder to get?
    By blackSS01 in forum Drivetrain
    Last Post: 07-17-2009, 12:55 PM
  2. Master and slave cylinder; couple of questions.
    By Aetos in forum Manual Transmission
    Last Post: 09-16-2008, 06:31 AM
  3. slave and master cylinder
    By ldanny in forum Manual Transmission
    Last Post: 05-19-2008, 05:05 AM
  4. Upgrade clutch master and slave cylinder?
    By Black02LS1 in forum Western Members
    Last Post: 04-16-2007, 07:31 AM
  5. 02 Slave and Master cylinder in 99 T/A
    By SicWs6 in forum Manual Transmission
    Last Post: 01-05-2007, 09:39 PM
