Results 1 to 20 of 20
09-16-2006, 11:11 PM #1The Pulse of the Maggots
- Apr 2006
- Fayetteville, NC
NBM- 1999 Trans Am WS6
02 Slave and Master cylinder in 99 T/A
I am upgrading my clutch and hydraulic system in my 99' T/A. I know everyone says to use the 2002 slave cylinder as a little upgrade, but what about the master cylinder for a 2002? Will that bolt right up to a 99, and would you recommend it? Is that what you are supposed to do upgrade the entire hydro. system to 2002? I would appreciate any help you guys have for me! Thanks alot!
09-17-2006, 12:55 AM #2Member
- Jun 2006
- USA
- 2001 SS
Yes. Upgrade the slave and master if you've got it apart. The '00-'02 are the same. They look exactly the same as your stokers but are different internally and they bolt up fine.
09-17-2006, 12:56 PM #3The Pulse of the Maggots
- Apr 2006
- Fayetteville, NC
Thanks for the info. I have also been reading in other threads about master cylinder(clutch) and people have been talking about a drill mod. Do you have any clue what that is?
09-17-2006, 01:27 PM #4Member
- Jun 2006
- USA
- 2001 SS
Yeah, there's a good write up on it here. Start on step 16 once you have the master out. You just disconnect the steel braided line, which you have to do anyways if you buy a new master becuase they don't come with one. Then get a 1/8'' drill bit and drill out the ~1'' spacer holding the line with vise grips. I've done it twice and it's really easy. Done in five minutes. The hard parts getting the master out. Oh and flush fluid through the line to wash out any metal shavings when your done.
09-17-2006, 06:20 PM #5Junior Member
- Apr 2006
- kentucky
red- 1999z
I ordered the master cylinder from fred beans and it came with the braided line and a new resivour all connected ready for install. Just FYI.
09-17-2006, 08:34 PM #6The Pulse of the Maggots
- Apr 2006
- Fayetteville, NC
Thanks alot, big help!! I also checked out fred beans website. I am ordering today.
09-17-2006, 10:36 PM #7Member
- Jun 2006
- USA
- 2001 SS
Oh, I guess mine didn't probably because it was the cheapest one. Made by LUK but still the same thing as the GM.
09-17-2006, 11:26 PM #8Junior Member
- Apr 2006
- kentucky
red- 1999z
toofazt----truth of the matter is my ls7 clutch kit from fred beans GM , it had "LUK" stamped all over it. so you are probably getting the same parts i did just at a cheaper pice...........................
SicWs6---- you might want to call fred beans if you were planning on ordering over the internet. I ordered on the internet w/o talking to them and came to find out there clutch kits were on back order. took a little over 2 weeks for them to ship it. Just a heads up
09-18-2006, 03:25 AM #9Evr sena bdgr killa snak?
- Dec 2005
- Research Triangle Park, NC
Pewter- '99 Z28 M6
If you order the master cylinder from GM, it will come with a new line. Unfortunately, you cannot buy them separately.
09-19-2006, 02:31 PM #10Member
- San Diego
Black- 1999 Camaro Z28 (SS kit)
Get the part #'s and check on GMpartsdirect.com also...prob cheaper...it will take two weeks though. I bought my entire new clutch from them including the heavy duty pilot bearing also.
Rich
09-20-2006, 04:32 AM #11Evr sena bdgr killa snak?
- Dec 2005
Pewter- '99 Z28 M6
Just finished with the same install. The new master was black, and the other was a silver metallic color, and they look different. My slave was SHOT. I can't believe the clutch even half worked. Bleeding it was surprisingly easy.
09-25-2006, 06:21 PM #12Junior Member
- Feb 2006
- NJ
black- 1998 SS
Someone said you have to drop the trans for this. Its dosent look like it from the installuniversity site. I have a 98 SS with the usual nasty clutch problem. So thanks to this posting I guess I need to order *both* the slave and the master from an 2002. Do they even sell the older "defective" 98-99 stuff? How much for these items? Any way to warrenty these items? I have a full coverage warrenty.
09-26-2006, 05:09 AM #13Evr sena bdgr killa snak?
- Dec 2005
Pewter- '99 Z28 M6
You need to go to the stealership, buy a master and slave cylinder, do the drill mod on the MASTER CYLINDER end of the line with a 1/8th in bit. The tranny has TWO sections, the bellhousing, and the gear case. PULL THE GEAR CASE OFF, not the bellhousing. If you want to bleed the clutch without someone's help, drill a pilot hole right beside the gas pedal, then when you got it about right, drill a hole big enough for an 11 MM socket to fit through.
It's a PITA without a car lift, I will tell you that right now. Set aside a Saturday.
11-19-2006, 06:33 AM #14Senior Member
- Nov 2006
- Indianapolis
So, even the new ones from the "stealership" (like that!) have to be drilled? I tried to do the drill mod and I am pretty sure I did not have the line clamped right because I was drillin', making good progress, then it suddenly felt like the restriction got pushed deeper in the line. Tried a longer drill bit, making progress again and it went in deeper! Still I have the same problems with my clutch pedal. Another friend told me to get a Z06 clutch master cyl. These also have the line attached like ours do, with no restriction tho?
11-19-2006, 08:34 AM #15Evr sena bdgr killa snak?
- Dec 2005
Pewter- '99 Z28 M6
You only have to drill about 1" to clear the restriction bro.
Remember, the restriction is where the line goes INTO the rear of the master cylinder. Remove that pin, and it will pop out. Wrap some 3/8 gas hose around the line, and clamp it with a set of vise grips. Then drill about an inch, little at a time so as to clear all the shavings out and not leave them in there, they might cause problems.
11-19-2006, 08:43 AM #16Senior Member
- Nov 2006
- Indianapolis
Yes, I did the drilling in the line right where it attaches to the master cylinder. I think I pushed the restriction deeper into the line while I was drilling, dammit. Does anyone have a 1/8 drill bit 12 inches long? lol
11-20-2006, 04:30 AM #17Evr sena bdgr killa snak?
- Dec 2005
Pewter- '99 Z28 M6
It might be 12", but its more like a 2.25" bit!
11-20-2006, 01:13 PM #18Senior Member
- Nov 2006
- Indianapolis
I am sure I pushed the restriction down in the line farther. After I re-installed everything, it made no difference on my clutch operation. It will still hang down low when I am gettin' on it. So, what is the verdict on the Z/06 clutch master cylinder? Does it have the line attached to the end like our cars do? Also, do I only need to get an '01 or '02 master cylinder? Those don't have the restriction in the line, or do all of them have the damn restriction? If I get a new '01 or later master cylinder, do I still have to do the drilling? How about if I replace the line only with another that has no restriction. Has anybody done that? Help me please, y'all!
11-21-2006, 06:58 AM #19Evr sena bdgr killa snak?
- Dec 2005
Pewter- '99 Z28 M6
I bought a new one, and it HAD the restriction. I just went through this crap about two months ago.
Your slave cylinder might be going bad if it hangs on the floor. That is too bad, cause you got to take the T-56 gearbox off to get to the SOB.
Sounds like your slave is going.
The restriction is molded into the end of the line, it is NOT an insert. If you pushed the bit two inches in there, then you prolly removed the restriction.
All you got to do now is check your slave. Are you losing clutch fluid? Does the clutch pedal sometimes lay on the floor on startup or while you are driving?
01-05-2007, 09:39 PM #20Junior Member
- Jan 2006
- Scranton Pennsylvania
Screw drilling a hole in the floorboard for self bleeding... just do what I did. Cut a section of wood the right size and place it against your seat bracket and the pedal... then get under there and bleed it
Personally, I think slave and master cylinders are replaced more often than they need to be due to people just not getting their system fully bled out...
Question: What slave/master cylinder to get?
By blackSS01 in forum DrivetrainReplies: 0Last Post: 07-17-2009, 12:55 PM -
Master and slave cylinder; couple of questions.
By Aetos in forum Manual TransmissionReplies: 0Last Post: 09-16-2008, 06:31 AM -
By ldanny in forum Manual TransmissionReplies: 4Last Post: 05-19-2008, 05:05 AM -
Upgrade clutch master and slave cylinder?
By Black02LS1 in forum Western MembersReplies: 4Last Post: 04-16-2007, 07:31 AM -
What is the diffrence between master/slave cylinder
By wonderboy in forum Manual TransmissionReplies: 8Last Post: 02-06-2007, 12:26 PM
