Results 1 to 3 of 3
    Member 1bad99ss's Avatar
    doylestown, ohio
    99 camaro SS
    ring and pinion...tires?
    i have a 99 ss m6 and i want to put 4:10s in the rear end and i was told to run them i need to buy tires that are 28 inches or taller???????? does anyone know about the gears and tire size matching?
    Member Corey1987's Avatar
    Greenville, NC
    1998 Z/28
    wouldnt that defeat the purpose of the gear change? U need to get ur computer retuned for the gear change via Hypertech PP3 or ls1 edit or some other sort computer programming software.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    going to 4.10 gears cut off top end mph pretty good. that's why you go to taller tires. you don't have to get get taller tires. i ran 4.10 with stock diameter tires. great acceleration. just ran 70 mph at 3000 rpms in 4th (auto).
  1. OEM GM 3.42 ring and pinion gears, used
    By 2000SSM6 in forum Parts For Sale / Trade
    Last Post: 07-06-2013, 09:08 AM
  2. Ring and Pinion Opinions
    By bberretta in forum Drivetrain
    Last Post: 07-31-2010, 02:16 PM
  3. RING and PINION???
    By 1bad99ss in forum Drivetrain
    Last Post: 01-04-2007, 06:48 PM
  4. wanted...ring and pinion
    By ramz-28 in forum Rocky Mountain Members
    Last Post: 10-20-2006, 12:23 PM
  5. fs: 3:42 ring and pinion
    By luch900 in forum Parts For Sale / Trade
    Last Post: 08-02-2006, 05:57 AM
