    Arkansas
    1998 Trans Am WS6
    WTB: LS1 prefer M6 10k or under
    I am willing to travel 300 miles from Camden, AR (south central AR)
    Looking for an M6 T/A (will consider A4 T/A's, M6 Camaro's, and M6 Formula's)
    Looking for a dark-colored car (Black, NBM, MRM, will consider other colors)
    Trying to keep it under 100k miles
    I have $10,000 to spend so show me what you got....
    Junior Member 97RAMAIRTA's Avatar
    Columbia, Missouri
    2000 Trans Am
    http://www.ls1.com/forums/showthread.php?t=39977
    if you buy it i'll bring it to you.
    gainesville
    2 (100%)
    blue
    1998 trans am vert
    I have a dark blue 1999 trans am M6 WS6 t-tops manual with 86,200 miles on it. It has tinted windows, new pasesetter headers, true duel exhaust, shaved door handles, phantom monster tach, duel guage pod with guages, borla exhaust, full stereo system with pull down dvd player, amp, subwoofer, new rims, hand painted detailing on the front, dry nitrous kit with purge. Also, less than a month ago the car got a brand new Z06 clutch kit, master cylinder, new kumho rear tires, new waterpump, pasesetter headers, and 02 sims. This is a very nice car, the only problem is that there is no compression in the 5 and 6 cilinder and I dont even have the money for the monthly payment anymore. I have 15 pics of the car and I can get some more if your serious about it. I need to sell this car quick! http://www.angelfire.com/blog/transampics/transampics
    $8000 obo
    I will go down to $7500 to give you some room to fix the engine up.
    Arkansas
    1998 Trans Am WS6
    ttt...
    Driving as fast as I can dafaic's Avatar
    Waxahachie, TX
    1 (100%)
    97 TA M6
    12 second lt1 $8,000 all maintenance upto date. Will need an opti to make use of the 6800 rev limit. The opti in the car just can't support that with the stock coil. $350 for a new opti. brand new moros 8.5 mm wires, 3 month old ngk palt. plugs, oil pressure sensor, mechianical oil pressure gauge, radiator hoses, fresh upper intake gaskets, some of the vacume lines replaced. Fuel pressure checkd and verified, new 02 sensors, , new header to ypipe gaskets, fresh mobile 10w30 extended performance super syn oil,. New o rings on injectors, madz28 tune 2 weeks old.
    Car has a small oil leak, needs opti, tear in driver seat on bolster, split in seam of back seat.
    Black leather, 6 speed, spec stage 3 clutch (still holds incredible will), several parts from the head cam swap. 98k miles. Could us reverse syncro...
    (i live 20 miles south of Dallas.)
    lt4 hot cam, l.e. heads, gold 1.6rr, hooker lts, 3"ypipe, hookercatback, no cats, subframes, b&m ripper, k&n cai, msd6a-coil-opti, udp, tr55 g's, ta girdle, 4.10's, boxed control arms, Madz28 tune, specstg3, alum. elbow. No traction
  1. How do you prefer coffee?
    By wheeliE-maxx in forum Almost Anything Goes
    Last Post: 12-02-2010, 12:16 PM
  2. I prefer Pemican....
    Last Post: 04-10-2008, 06:28 AM
  3. Which Web Browser do you Prefer?
    By Dax in forum Almost Anything Goes
    Last Post: 03-11-2007, 08:27 AM
  4. What car would you prefer
    By White Cobra in forum Firebird / WS6
    Last Post: 12-03-2006, 10:19 AM
  5. Cam Timing - what do you prefer?
    By hammertime in forum Internal Engine
    Last Post: 02-20-2006, 09:15 PM
