Thread: higher redline
    Member 99-SS-Conv's Avatar
    Palm Harbor, FL
    1999 Camaro SS Conv
    higher redline
    does anybody know is I have a 200 camaro ss with the ls1 and I get a cam with .575 lift a ls6 intake manifold and ls6 heads with comp springs is my redline gonna be higher? cause an ls6 make all of its power at 6,000 and that my redline
    Member Huskerz1's Avatar
    99 SS Vert M6
    Your ls6 intake will make more power across the board. You will definitely benefit from rasing your limiter tho. However, on a stock bottom end, I wouldn't raise it higher than 6600 rpm. Others might go higher but I see no need for what I want out of my car.
    Senior Member
    rochester,ny
    pewter
    2001 z28 lingenfelter 383
    my bottom end is not stock and it seems to cut me off around 6800....its pretty high..i try to shift in the low 6000s anyways
    Palm Harbor, FL
    1999 Camaro SS Conv
    so yes it will be extended with no bad effects
    DFW
    '18 CTS-V
    '13 ZL1
    a tune will help get you to raise your shift limit, that or a hand held programmer. personally i would spend the money on a good tune...
    i have mine set (HP Tuned) at 6600 after intake, heads, cam, headers, exhaust, and other mods as well...
    2013 ZL1: °°590rwhp/576rwtq°°
    Senior Member Wheeler99WS6's Avatar
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    tuner can raise your rev limit, probably will do that when dyno tuning to get the most of your setup for WOT tuning.
  1. Redline
    By Spikito in forum Almost Anything Goes
    Last Post: 05-27-2009, 05:36 PM
  2. lower tire press. higher ET, higher press lower ET???
    By greatwhiteZ28 in forum Drag Racing
    Last Post: 10-20-2007, 05:57 PM
  3. has anyone seen redline ?
    Last Post: 04-26-2007, 02:58 PM
  4. rx-7 first gen no redline.
    By zero_proto in forum Western Members
    Last Post: 03-09-2007, 09:11 AM
  5. redline?
    By simsridnbigrims in forum General Help
    Last Post: 02-23-2007, 01:07 PM
