Results 1 to 20 of 21
Thread: redline?
02-17-2007, 06:45 PM #1Junior Member
- Feb 2007
- east brunwick
redline?
hey guys, i just wanted to know what is the redline for a stock LS1?
02-17-2007, 07:04 PM #2Senior Member
- Jul 2005
- Jacksonville, FL
If I'm not mistaken stock rev limiter is set at 6200.
02-17-2007, 07:27 PM #3King 0f n00bz
- Jan 2006
- Shepherd, Michigan
red starts at 6k and ends at around 7k...rev limiter is set to 6200..or is it 6500 ... and i'm pretty sure at stock she will completely redline max at 6800ish....
02-17-2007, 07:32 PM #4
02-17-2007, 08:08 PM #5Slower Than a 3rd Gen
- Cape Coral, FL
Mystic Teal- 99 Trans Am & 01 CBR 929
umm.. i set my rev limiter to 6800 and floated a valve and backfired my nitrous. rev limiter is set at 6200 for a reason. I had mine at 6400 forever and it held up pretty well but the stock valve train wont hold much over that. If you got some double coiled springs and new retainers and chrome moly pushrods it would rev much higher...
02-18-2007, 09:59 AM #6
The valve springs are the weak link... Upgrade them, and you will rev higher, safer !!! Mine is up to 7800 !!! ( HP Tuner )
02-18-2007, 10:57 AM #7
02-18-2007, 11:05 AM #8
The cam I'm running is rated 2200 - 7200 rpm. I go through the finish line at 7200 in 3'rd 1/4 mile. Love screaming that LS1 !!!
02-18-2007, 11:08 AM #9
I've bounced off the rev limiter while spraying at 7800 already... That hurts the feelings a little...( while figuring out the shift programming )
02-18-2007, 02:14 PM #10
02-18-2007, 02:48 PM #11
02-18-2007, 03:04 PM #12
Actually, yes, and it's never been touched...That's why I'm in search of a stroker or short block ! Don't know if I will get another season out of this one !!!
02-22-2007, 10:27 AM #13Member
- Feb 2007
- FairField, CA
RED 35TH ANIVERSARY PKG- 2002 CAMARO SS 35th LE
Dude The Rev Limtier Pops At 6200rpm Stock!!!!!!!!!!!!!!!
02-22-2007, 01:45 PM #14
02-22-2007, 03:28 PM #15
02-22-2007, 03:37 PM #16
02-23-2007, 10:04 AM #17
02-23-2007, 01:59 PM #18
I have my limit set at 7800, but I ussally go through the traps at 7200... I was have shift programing issues, causing over revs and still hitting the limiter... Bummer when your spraying...Lucky for me that the limiter kills fuel, not spark...
The top end is ported & flowed very well, wein intake, 80mm BBK, comp cams, 1.8 rockers, holley 32lb injecters, 4600 locker stall, moser 12bollt w/ spool, every rear suspension mod plus the anti roll bar. It pulls 1.36 60foots 10.79 @ 124 mph
02-23-2007, 02:02 PM #19
Hey Juiced, just curious, what NOS system are you using ? I'm using a 150 dry & bumping my WOT for more fuel. ( HPTUNERS )
02-23-2007, 02:06 PM #20
Redline
By Spikito in forum Almost Anything GoesReplies: 19Last Post: 05-27-2009, 06:36 PM -
Who's been to Redline Raceway?
By fast enough Z28 in forum Texas MembersReplies: 15Last Post: 03-04-2008, 02:50 PM -
has anyone seen redline ?
By Speedy_Gonzales in forum Almost Anything GoesReplies: 6Last Post: 04-26-2007, 03:58 PM -
rx-7 first gen no redline.
By zero_proto in forum Western MembersReplies: 25Last Post: 03-09-2007, 10:11 AM -
Redline
By 2001bird in forum General HelpReplies: 6Last Post: 10-19-2006, 09:01 AM
