Results 1 to 20 of 23
    Member RDS's Avatar
    Aug 2006
    Portsmouth Ohio
    99 WS 6
    NEEDED:Fuel Rail Cover install instructions for LS1
    Anyone have Fuel Rail cover installation instructions for an ls 1?
    Thanks Rich
    Member RDS's Avatar
    Aug 2006
    Portsmouth Ohio
    99 WS 6
    anyone know how they are attached?
    38 of 139 PontiacFan's Avatar
    Kearney, NE
    2001 Pontiac
    Simple, they have c-clips built-in to the back of them that just snap in place.
    There are no instructions necessary. If you have one in hand & can't figure out how it goes on, ...
    I will try to remember to write up a nice walk through on the install of this later this evening
    Painted manta stripe
    Member RDS's Avatar
    Aug 2006
    Portsmouth Ohio
    99 WS 6
    Shweet thanks guys.
    Step by step install:
    http://thecheckeredflagstore.com/frcs_install.php
    A few pointers:
    Before you install the fuel rail covers(FRC's) I would recommend covering the backside of them with heat shielding tape. I applied the heat tape to the back of mine for what its worth and I have had them 3 years now I believe.
    When you go to install the covers, you obviously want the motor nice and cool.
    If you have a STB, it must be removed to install the FRC's. The oil cap & dipstick have to be removed for the passenger side as well. On the driver side, you have to remove all the heat tape on the 2 fuel lines. Do this before you attempt to install the driver's side, or you will chip and scuff up the paint on it. Its not necessary, but it would make the install easier if you just disconnect the fuel lines all together and reconnect them after the FRC has been installed. Thats about all the pointers I can think of. When you are finished it should look something like this:
    I don't deserve all the credit for the pointers & write up, I borrowed some of the info from Parbreak who does all the FRC work for Afterthoughts.
    Member RDS's Avatar
    Aug 2006
    Portsmouth Ohio
    99 WS 6
    Good deal. Since I ordered stock corvette fuel rail covers will I need to cut on them to make them fit?
    Quote Originally Posted by RDS View Post
    Yes
    Jenks/Tulsa
    Light Pewter Metallic
    y2k 8-cylinder catfish
    Nice lookin' engine bay Y2KPewterSS!
    2000 Chevrolet Camaro Z28 A4 - Light Pewter Metallic
    Direct Flo lid, SLP Loudmouth, Bassani Offroad Y-Pipe, BMR strut tower brace, BMR subframe connectors, shift points tune and !EGR
    2011 Kia Forte EX A6 Sportmatic - Titanium Silver Metallic
    Member jmhvenom's Avatar
    Cincinnati, OH
    2002 Z28
    install is very easy if they are cut right, if not... good luck
    College Station TX
    2000 &2002 Z28
    Lol i got GTO covers on mine.....All u gotta do is move the wires out of the way and put em back and snap em right on
    Just mess with it a little i promise u ull figure it out.....Dont be scared
    Member RDS's Avatar
    Aug 2006
    Portsmouth Ohio
    99 WS 6
    Ok got the passenger side on does anyone have a pic of the drivers side with the cover on?
    See if these help
    Member RDS's Avatar
    Aug 2006
    Portsmouth Ohio
    99 WS 6
    Yep that helped a lil. I guess wut I need to know is if its nessasary to cut any of the cover on the back side to make them fit any better. I cant get the front of the passenger side to sit on the fuel rail that well.
    I Think, Therefore Z-28 Corvettekid82's Avatar
    Deland FL
    Triple Black
    2001 Z-28 Vert
    is your car automatic or standard? Also do you still have the AIR tubes in place on your headers? Sometimes for the A4's you have to trim a little bit for the tranny dipstick. If its catching on the AIR tube from the headers you can either !AIR or just try and bend the AIR tube out of the way. I know that once I removed mine, it was a night and day differance in installing the FRCs.
    Is there anyway you can post a pic of how it currently is? We could probably help you a lot if you could.
    Member RDS's Avatar
    Aug 2006
    Portsmouth Ohio
    99 WS 6
    ok will do.
    thanks rich
    Jenks/Tulsa
    That engine bay ='s the sexor.
    Member RDS's Avatar
    Aug 2006
    Portsmouth Ohio
    99 WS 6
    Ok think I finally got it
    The dipstick for the tranny, you have to bend it out of the way, its definately going to cause fitment issues. Also, since you still have the EGR I am assuming you still have the AIR pump and those are your other obstacles. Have you had the codes for the AIR and EGR turned off? If you have pull that stuff out of there and you will have a much easier time installing the FRC's
  1. Wanted: WTB: corvette fuel rail cover
    By fosingwo in forum Parts Wanted / Trade
    Last Post: 04-18-2010, 11:07 PM
  2. Fuel Rail Cover Decals???
    By homerunhtr21 in forum Appearance Section
    Last Post: 08-20-2007, 05:40 PM
  3. CF fuel rail cover?
    By turbols1chick in forum Firebird / WS6
    Last Post: 02-21-2007, 09:09 PM
  4. Fuel Rail Cover Help!
    By CWW17 in forum Appearance Section
    Last Post: 11-15-2006, 01:28 PM
