    NC
    Why does the owners manual say to increase tire psi to 38 when driving over 100mph?
    Won't doing so decrease traction?
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    to decrease resistance, so one can get better fuel efficiency, by sacrificing grip, though.
    I wouldn't do it.
    Eugenio_SS
    I Think, Therefore Z-28 Corvettekid82's Avatar
    Deland FL
    Triple Black
    2001 Z-28 Vert
    I'd think it would compensate for the expansion of the sidewalls from spinning so fast. You know how the sidewalls flex like mad on Drag radials when they burn out.. wouldnt street tires expand a bit as well at high speeds?
    Senior Member predator's Avatar
    Little Rock, Arkansas
    1966 Corvette Coupe
    my guess would be that low tire pressure will increase heat production do to more deformation of the sidewalls. at 100 mph your getting twice the deformation per second as you would be at 50 mph means around twice the heat... heat and tires arent good... seperation and blow outs could occur.
    only my$.02
    and grip is caused by friction... and your thinking if you inflate your tires youll loose size on your foot print... and friction actually has nothing to do with contact area, only force applied (weight) and friction coefficeint.
    Jun 2002
    Montreal, CANADA
    triple-black
    Quote Originally Posted by Corvettekid82
    no... since they are constructed of steel layers as well as nylon layers.
    Jun 2002
    Montreal, CANADA
    triple-black
    also, another thing to remember is that @ higher speeds, you increase the tire temp, which increases the pressure already... no need to increase it even more and change the contact patch shape.
    Member bbfirebird's Avatar
    AZ
    2000 Formula hardtop
    Quote Originally Posted by Eugenio_SS
    i second this.
    Deland FL
    Triple Black
    2001 Z-28 Vert
    things that make you go 'hmmm'
  1. Tips on manual driving
    By MRM 01 in forum Almost Anything Goes
    Last Post: 07-23-2010, 04:14 AM
  2. Question: owners manual..
    By reaper ws6 in forum Camaro / SS
    Last Post: 07-09-2010, 09:06 AM
  3. driving 6 speed manual on ice
    By lookngoodSS in forum Camaro / SS
    Last Post: 12-23-2009, 09:32 PM
  4. Owners Manual
    By Fred H. in forum Firebird / WS6
    Last Post: 04-30-2008, 06:06 PM
  5. Owners manual questions
    By metsatvz400 in forum Camaro / SS
    Last Post: 11-16-2006, 07:51 AM
