Page 1 of 3 123 LastLast
Results 1 to 20 of 47
    Junior Member lookngoodSS's Avatar
    Oct 2009
    dayton
    02 SS camaro
    driving 6 speed manual on ice
    i got caught driving my 02 ss camaro (6 speed manual) on ice last night and it was the scariest thing in the world. What i did was try to make it so my rps were as low as possible. my friend told me that i should always drive in second gear? i tried starting in second gear but my tires just spinned. any advice at all would help. thanks
    Member TexasLS1's Avatar
    Cedar Park, Texas
    '72 Chevy C10 SWB
    Replace wheels with tracks? Idk. I drove my 01 SS M6 for 2 winters in Utah because i had no other vehicle at school, and there were days i walked instead of driving lol. Luckily I never wrecked or got so stuck that I couldn't get out. I tried 2nd gear, even 3rd a few times, and would slip the clutch so bad it would make me cry, but still had trouble. I just tried to drive as little as possible and keep the car rolling (not come to a complete stop). Good luck!!!! Take it slow and be careful!!!
    Go slow, keep the RPMs low and give yourself plenty of room to stop. Use the brakes sparingly, try to slow down using the brakes as little as possible.
    Member camaroz98's Avatar
    Sep 2009
    las vegas
    blue
    1998 camaro z28
    lots of weight in the trunk that helped me when i had my 99 i was 16 and my first winter sands bags put into a sheet (so sand cant get out) work well
    TEKNIK Teknik_SS's Avatar
    UTAH
    2001 Camaro SS #1469
    Quote Originally Posted by TexasLS1 View Post
    Gotta love the Utah snow! She has only seen the snow twice and it was hell both times! The ASR Sucks with the M6!! I would find a cheap ass beater for the winter!
    Member jeffsWS-6's Avatar
    Winchester,CA
    BLACK
    2001 WS-6
    for slowing down use the gears and down shift. but i agree, dont drive it unless necessary. i drove mine on ice as well, felt like ice skating with a car. if you need to drive it, they also have studded tires.
    Michigan
    SOM
    2001 WS6
    These don't do well at all in snow (or ice). I got caught in it once when the car was 2 months old. Best solution is to not drive it and if need be, drive very slow. Keep the RPMs low and use higher gears. Ignore other people trying to get you to go faster. Let them pass you.
    Member anniversary30's Avatar
    Illinois
    White/Blue
    99 Trans Am
    Get a beater and just thank god you don't have an auto. You don't even get a chance to touch the gas with auto. They say bridgestone blizzaks (sp) tires are supposed to be great for winter time. Try a set of those. A friend with a cobra had them and said he could go anywhere in the winter.
    Junior Member nevrfastenough01z's Avatar
    Dec 2008
    New Jersey
    2001 Camaro Z28
    get a set of cheap wheels that are thinner, put winter tires on them, and add weight.
    Junior Member yanoZ28's Avatar
    Oct 2009
    Killeen Tx.
    2001 Z28
    Yeah auto sux, Id slap a set of winter tires on there and hope for the best
    Senior Member Getzen_Guy's Avatar
    Oklahoma
    2000 T/A
    Quote Originally Posted by anniversary30 View Post
    I just walk to work when it snows
    Member 01 LS1 Formula's Avatar
    aurora colorado
    2001 formula
    i have an auto with 510 hp with drags and it snow a here in co a couple of days ago and that sucks ass
    Senior Member 00LS12LS6Z28's Avatar
    Bristow, VA
    2000 Camaro Z28 (sold)
    Take your turns very slow and no gas. No ASR either it won't help. Tap your brakes or try not to use them if you don't need to...
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    as i DD my car in winter (michigan) ..mine is an auto and i do alright..the trick is as little throttle as possible..and do a lot of rolling ..when ever changing lanes or turning..never hit the throttle ...however this year i just bought winter tires..and they are a god send..it takes work to fish tail in the slush and snow ..i just need to add some weight to the back now and i will be set...but still ..drive with common sense and you will be ok.
    Member SAGGIN's Avatar
    Elk Grove, CA
    RED
    02 SS, 03 BMW 745
    Don't let your foot fall asleep on the gas...lol. If the ice is that bad you could use chains right?
    LSwut tep98ws6's Avatar
    Jun 2009
    Saint Louis, MO
    Arctic White & Black
    '98 WS6 M6 - SWAPTIME!
    4th gear, braking well before coming to a stop and lots of weight in the back. that's how i got home in sleet!
    MOTOR CITY MARO' SSTODD's Avatar
    LIVONIA,MICHIGAN
    PEWTER
    2000 CAMARO SS #3821
    Also, almost every 275/40/17" tire is a summer rated tire that is never to be driven in cold temps. because the rubber compound cannot take it. Makes it like driving on rock hard slicks.
    Senior Member Z28_Driver's Avatar
    Jun 2009
    Ohio
    Sunset Orange Metallic
    2002 Z28 Hardtop
    My auto does okay in the snow until I try to get up my driveway. 30 degree incline that increases to 45 in the last 100 feet.
    Get a 4x4 suv or old pickup. Other thatn that. just follow the suggestions already made.
    I don't chains will work on the 4th gen. at least not with the stock wheels.
    Michigan
    2001 Camaro Z28 A4
    Not a great idea to drive a rear wheel drive vehicle in slippery conditions especially low rpm-high torque rwd cars like ours. I had the misfortune of being caught in a sudden-no warning freezing rain. Needless to say, my car spun out of control going only 25 mph. The mere shifting of gears put me into that situation. Didn't help that I had a shift kit either. After that, I was within a mile of getting home and had to exit a road with a 25 percent incline and I ended up going sideways and back down the slope with oncoming traffic. Good thing some people had common sense and stopped. Took about six people to help coax my car back up the hill. And when I finally got home, I couldn't make it up the driveway. Car stayed parked on the street.
    Big Gulps, huh? HOBS's Avatar
    Idaho
    1999 Trans Am
    I had a buddy tell me once to upshift to slow down cuz downshifting will make you spin out dunno if its true I don't drive manuals in winter. My T/A handles just fine with the auto as long as you don't drive with your head up your ass. Then again I prefer RWD or 4WD vehicles to FWD vehicles in any road condition.
  1. Driving School that Teaches Manual Shifting
    By M-ManLA in forum Western Members
    Last Post: 07-17-2012, 07:56 AM
  2. Tips on manual driving
    By MRM 01 in forum Almost Anything Goes
    Last Post: 07-23-2010, 04:14 AM
  3. Supra + 6 Speed Manual = 7s in the 1/4
    By Superluminal in forum Drag Racing
    Last Post: 01-19-2009, 12:42 PM
  4. WTB 5 speed manual
    By LS1-450 in forum Parts Wanted / Trade
    Last Post: 09-22-2005, 01:57 PM
  5. Replies: 7
    Last Post: 08-09-2005, 09:52 PM
