    ¿LS1 Anyone? Contra[SS]'s Avatar
    Mountain View, California
    Onyx Black
    Changing the shifter knob Ques
    Hey guys, I wanted to change the stock "hurst" shifter knob on my M6 to a classic round (sphere) one... My question is:
    Can I just twist/take off the stock knob one or do I need to replace the whole shifter stick?
    Or is it worse than I though it would be and have to replace the whole thing and get a new shifter/short throw kit?
    Silver02TA
    Guest
    twist off, then twist new one on... assuming they have the same thread patterns
    Onyx Black
    Quote Originally Posted by Silver02TA
    Just tried it and it doesn't want to move at all. It starts torque-ing the stick and the stick bends alittle...
    So do I keep on twisting ignoring the little flexing of the stick? Or do something else?
    Member graphicsgod's Avatar
    Orlando, Fl.
    1999 Chevy Camaro
    It should unscrew on M6's. On an auto, you have to remove a pin (which is a real PITA BTW), and then it pops off.
    Maybe it's glued on .
    Also try a wrench to hold the stick, and larger one (ie. a pipe wrench) to use to twist the "knob". Since your replacing it, doesn't matter if it gets scratched. And the stick gets covered by the boot. Not sure why it's not moving...
    Rob
    redls1bird
    Guest
    mine needs a little persuasion from time to time to remove it. maybe from the heat cycles it goes through?
    Onyx Black
    Quote Originally Posted by redls1bird
    Hmmm... dunno. Been like this ever since I got it. Well, I'll try the wrench thing when I find the exact shifter knob that I am looking for. Thanks guys!
    WS6 to Z06 TransAmMan's Avatar
    Iowa
    02 Z06
    I have the same problem man so it's not only you. When replace my clutch. I tried to remove the shift nob and did the exact same thing. Good luck though!
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    from the factory they put loctite on the know threads so you gotta twist really hard. If I were you, get a short stick and an aftermarket knob. Trust me, you'll appreciate the shorter throws
  1. Changing the Auto Shift knob
    By BANDITCAR in forum Appearance Section
    Last Post: 12-02-2010, 02:55 PM
  2. shifter knob
    By Darkrider02 in forum Camaro / SS
    Last Post: 07-15-2010, 11:39 AM
  3. Shifter knob?
    By jmb72 in forum Automatic Transmission
    Last Post: 10-22-2007, 09:47 AM
  4. shifter knob?
    By slpgto2004 in forum GTO
    Last Post: 10-20-2007, 11:48 AM
  5. Shifter knob
    By Scorch in forum Firebird / WS6
    Last Post: 04-21-2006, 06:54 AM
