Results 1 to 15 of 15
    Member Blackout's Avatar
    austin, tx
    2002 Mustang GT
    steering wheel controls
    do all maro's and TA's have radio controls on the steering wheel. if so what years/mod. offer this? thanks
    Lancaster, PA
    2000 Z28 (sold)
    2000 and newer camaros are the only years offered for them. I think 93 and newer they were offered for the firebirds.
    02z28
    Guest
    Just a reminder for the guys that do have the steering wheel controls, if you replace the factory radio you will lose steering wheel controls. However for most vehicles, an adapter for like 70 bucks is available.
    Member Thewilldog's Avatar
    Jacksonville, FL
    2001 Z28
    Quote Originally Posted by 02z28
    Yeah, the PAC-IX adapter. Doesn't work in my 01 Z28 for some reason though.
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    I've heard some guys say that it will still work, but I would really hate to lose mine. I do like it, but if you are playing and got some bad ass music going your liable to change the station. THat is the only part that sucks.
    Drexel Hill, Pa
    Those aftermarket steering wheel control adapters are a PITA to install.
    Colorado
    99 Z28
    Quote Originally Posted by Thewilldog
    Who hooked it up and what is it doing or not doing?
    Jacksonville, FL
    2001 Z28
    Quote Originally Posted by DrMilhouse
    I installed it. I bought an Alpine CDA-9833 w/ remote. I connected the green SWI-X wire to the Dark Blue in pin 13 (or 14, don't remember.) I know it's the correct wire, because I had to cut it, and afterwards I tested the whether or not the steering wheel controls worked with the stock radio without this wire connected (they did not) and again with the wire reconnected (they did).
    I programmed it for the correct version (version 1) and tried to program my first steering wheel button. I would hold down the steering wheel button until the left LED went off, but the right LED would never come on to indicate it had recognized the steering wheel button and was waiting for a command from the remote. The damn thing just times out everytime. Maybe I got a bad unit. Waste of $45.
    Rock-n-Roller White Rascal's Avatar
    OHIO Go Buckeyes!
    '07 Trailblazer LT
    Quote Originally Posted by slayer6x6
    I totally disagree with this statement. The PAC SWI-X only has 3 wires to connect and the mounting of the infrared LED. It couldn't be much simpler than that. Here's how my LED is mounted. Before I got the custom trim ring it was mounted below the HU in the Metra install kit I was using at the time. The LED actually works better in this location than it did when I had it in the cup holer facing toward the HU. The SWI-X control box is wrapped in a piece of carpet and tucked in the dash under the HU. Programming the unit was a piece of cake too.
    The White Rascal SOLD
    Crank up the drums, crank up the bass,
    Crank up my Les Paul in your face!
    ruff ruff rotwiler's Avatar
    WA State
    LT's, 3400 stall, FIPK,CB
    2002 Z28
    I have a PAC swi-x was a simple couple minute install. Only thing that was time consuming was finding a good place to mount the LED(ended up putting it above my HU facing down). Also when programing the SWi-x you have to do it fairly quick or it will finish and you need to start over. Just did the same thing in my other car and mounted the LED below the HU, is pretty simple to do.
    WA State
    2002 Z28
    Was just thinking of this and thought I'd let you know. The PAC SWi-x does work and will on your car. I bought a pac-swi-x to do my other car and tried everything and didn't work. Emailed PAC, they said may be defective unit, took it back and new one worked the first time. If it isn't defective, make sure you read the manual very good and don't skip anything, setting # for type of car etc...PAC website also has a walk through PAC programming for Dummies. I think they have a new PAC SWI-ALP which is supposed to plug in the back of newer, JVC, Kenwood and Alpine wired remote inputs, but unsure if it works with the FBody. If it does it would be as simple and hooking up a + and - and plugging it into the stereo which would be really easy and probably have to set the PAC for type of car and brand of HU. Also when I first hooked up the SWI-x in my Camaro I connected the wrong wire for the steering wheel controls and was going nuts trying to figure out the problem, but there are 2 blue wires, 1 is for the steering wheel remote and the other is for the back speaker.
    Also for those who are interested, Soundgate makes a interface)remote3) to retain steering wheels controls for the Camaro, but price is around $95
    Sedalia, MO
    2000 WS6
    I just installed the ECLIPSE AVN2454 6.5" screen in my dash and list my steering wheel controls. Can i get them back and still have my remote for my TV DVD and navigation work?
    OHIO Go Buckeyes!
    '07 Trailblazer LT
    Do a search for PAC SWI-X
    Jacksonville, FL
    2001 Z28
    Quote Originally Posted by rotwiler
    Yeah, I know it should work. Prior to the big crash here, I had a thread going with another person who had the exact same stereo as me in a Camaro and got his adapter to work. I bought my adapter online, so I don't know if PAC would help me or not. I know it's wired correctly, it just won't accept inputs from the steering wheel.
    Oh well. I've just been using the stereo remote, and I don't miss the steering wheel buttons anymore.
    Junior Member black_bart's Avatar
    Florida
    1999 Trans Am
    WhiteRascal, Where did you get the custom trim piece from? It looks stock, like it was made for the 1.0 DIN HU.
  1. Steering wheel controls?
    By stew215 in forum Stereo and Electronics
    Last Post: 06-30-2010, 10:09 AM
  2. Question: Steering wheel Controls
    By Adam_94_T/A in forum Stereo and Electronics
    Last Post: 11-05-2009, 09:12 PM
  3. Help: Steering wheel controls
    By joevee1446 in forum Firebird / WS6
    Last Post: 09-01-2008, 05:30 PM
  4. Help: Steering wheel controls
    By joevee1446 in forum Stereo and Electronics
    Last Post: 08-28-2008, 06:41 AM
  5. Steering wheel controls?
    By jag42420 in forum Stereo and Electronics
    Last Post: 01-19-2007, 04:17 AM
