    Junior Member topgun1851's Avatar
    Virginia Beach, VA
    '02 WS6 Procharged 9psi
    Spohn Torque Arm
    Posted this in the suspension/handling section, but I see it as chasis, which there is no tab for that.
    Starting to hear some noises from my torque arm because its starting to loosen up. When I got under the car and started shaking it around to see where it loosened up, I found it where it attaches to the braces that attaches to the car (see pic, loose at the arrow). At the arrow, I can move the joint up and down 1/8-1/4 inch. The torque arm has been on the car for less than a year. Anyone have advise how to tighten it up, or what can be done to fix/prevent it from happening again? Thanks in advance.
    Member barryTA's Avatar
    Aug 2006
    ARIZONA
    2001 trans am
    have you tryed tighten it with an open end rench?
    Aug 2006
    ARIZONA
    2001 trans am
    before you tighten it you might want to use some lock tight
    Virginia Beach, VA
    i dont think squeezing the heck out of it will help... it might for a few days, but that will loosen up again... its something internal, i think
    Aug 2006
    ARIZONA
    2001 trans am
    is it moving around after you tighten it ?meaning is their any play after you
    tighten it? if so you have a different problem if it dont wiggle around after
    you tighten it then you should use lock tight when you tighten it. and that
    should stop it from coming lose.
  1. For Sale: Spohn Torque Arm
    By 02 WS6 TA in forum Parts For Sale / Trade
    Last Post: 01-03-2012, 01:37 PM
  2. Torque arm, Spohn BMR or UMI
    By 6speedTAthistime in forum Suspension and Handling
    Last Post: 06-08-2008, 01:41 AM
  3. Spohn torque arm
    By SS#1531 in forum Parts For Sale / Trade
    Last Post: 11-28-2007, 03:18 PM
  4. Spohn torque arm
    By u69038 in forum Suspension and Handling
    Last Post: 01-12-2007, 03:02 PM
  5. Do SPOHN SFC's mix w/ Torque Arm?
    By ihatemustangs in forum Suspension and Handling
    Last Post: 06-25-2006, 01:09 PM
