Thread: Diff. between Z06 and Regular C5
01-11-2007, 03:46 PM #1
This may have been asked many times already but i searched and couldnt find the answer, what is the difference engine wise between a regular C5 Corvetter and a C5 Z06? Thanks all.
01-11-2007, 07:03 PM #2Junior Member
- Oct 2006
- Cali 707
Silver- 1997 Corvette
The ZO6 has the LS6 engine and is rated at 405HP beginning in 2002.
It has the LS6 intake, larger cam larger cc heads, bottom end of engine is stronger and the Ti exhaust cat back system. All came with the M6 tranny and a 3:42 differential with shot peened gears and stronger axles.
01-11-2007, 07:21 PM #3
01-12-2007, 02:09 AM #4
C5's are either couples, or convertibles, automatic or manual tranny.
Z06 are all fixed roof coupe (hard top) they're all manual. and they weight significantly less than the regular C5. Also, the front and rear tires are different sizes than the C5. Z06: 265/40/17 front, rear 295/35/18
They have rear brakes air ducts, as well as in the front. No fog lights like the C52007 Audi RS 4
01-13-2007, 02:38 PM #5Junior Member
- Oct 2006
- Cali 707
01-14-2007, 05:47 PM #6Junior Member
- Jan 2007
- Levittown, Pa
Pewter- 2000 FRC
Z06 - C5
All 2001 and up Corvettes have the same intake.
The M6 trans is the standard trans, the Z06 has the M12 (Wider ratio) trans.
The body style (Hardtop) was available in 99 & 00 with limited exterior colors and any interior color as long as it was black. The hardtop is lighter than the Coupe or Vert.
I don't know about the stronger axles, but I don't think so.
Bob K.
01-16-2007, 10:53 AM #7
Didn't the Z06 have thinner windows/windshield for 'weight saving" or something? oh, and different suspension?
And I think the early ones were rated at 385 hp.
01-16-2007, 02:27 PM #8Junior Member
- Jan 2007
- Levittown, Pa
Pewter- 2000 FRC
01-16-2007, 02:33 PM #9
01-18-2007, 02:18 PM #10Corvette Moderator
- Sep 2005
- Essexville
Jet Stream Blue- 2009 Lingenfelter ZR1
Great answers, and they also have a Z06 specific gauge panel.
01-18-2007, 04:34 PM #11Member
- South of Heaven
Navy Blue Metallic (NBM)- 2002 Camaro SS
01-21-2007, 05:21 PM #12
starting in 2001 the z06 came with the ls6 rated at 385hp then in 02 405hp. the windows were shaved on the z06 to save weight. like 4 lbs i think.
Premium gas vs. Regular
By SSjunior in forum Almost Anything GoesReplies: 25Last Post: 06-12-2010, 12:51 AM -
diff between WS6 to a regular TransAm
By 2001 1LE in forum Firebird / WS6Replies: 43Last Post: 01-03-2009, 05:44 AM -
WS6 to regular T/A
By Crank in forum Firebird / WS6Replies: 3Last Post: 09-11-2006, 05:17 AM -
Regular v. Premium Gas
By jkf243 in forum GTOReplies: 22Last Post: 06-24-2006, 03:57 PM -
best diff fluid? good diff cover?
By ErikElvis in forum Camaro / SSReplies: 3Last Post: 03-23-2006, 08:49 PM
