Results 1 to 20 of 26
    Junior TX Member SSjunior's Avatar
    Tyler, TX
    Navy Blue
    2002 Z28 A/4
    Premium gas vs. Regular
    What type do you use on your daily driver?
    My dd is an Mitsubishi Eclipse 2000 2.4 L V4 it has about 112k miles. I have been using premium gas on it.
    Does premium gas actually help?
    park bench
    gmcheviac
    no, you're wasting your money if the manual doesn't call for it. it can actually hurt performance and mileage (slightly), just like if you were to take timing out of the tune.
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    My dd is a 2002 Avalanche and i use the middle one on it. I just don't like the sound of Regular and i don't wanna use Premium on it either so the middle one works but its only Chevron for my cars
    Apr 2009
    Palm Desert, CA
    97 3.8L Firebird 5 Speed
    That's what I was taught in my automotive classes, I would agree with this.
    Sep 2008
    Kennesaw, GA
    2005 Toyota Corolla (DD)
    Higher octane reduces detonation by being less "flamable", for lack of a more sophisticated term. Like everyone said, if the manual doesn't call for it there are no performance gains to using it, unless you increase compression, advance the timing, etc.
    Member tnthub's Avatar
    Brunswick, Maine
    1994 Camaro Z28
    I use the lowest octane that does not knock... Higher octane take more spark to ignite. The goal is to use the lowest octane that works for your vehicle without knocking. Lower octane is generally easier on the vehicle in cold weather conditions. Too much octane will actually hurt performance.
    91-93... my TA is my DD...
    2001 Pontiac Grand Ma GT
    125K miles
    Gets 85 octane. Doesn't ping, so it is enough.
    park bench
    gmcheviac
    Does it ping? That engine was designed to run on the worst of the worst grocery store gas while towing alot of shit or driving around with the e-brake on (damn women). Sorry if stereotyping it as a soccer mom mobile offends you
    Feb 2008
    NEW JERSEY
    PEWTER
    2001 TRANS AM WS6
    REGS in the shit box
    Crystal Lake IL
    2001 Camaro Z28 M6
    93 in the camaro (cammed/tuned)
    87 in the trailblazer
    87 in the honda
    93 in the motorcycle.
    as said above if the car does not knock, and is not tuned and the manual does not call for premium, then use regular. otherwise your wasting money.
    park bench
    gmcheviac
    Though with a real tune (mail order or in person, no supershits) for premium that avalanche would pick up nicely silverws6. Though the most noticible difference will be from torque management along with shift pressures and patterns
    Omaha, NE
    2000 Z28 Camaro
    87 without ethanol
    Senior Member
    Mar 2009
    Milwaukee
    Arctic White, red/gray
    1997 Corvette, 92 Typhoon
    93 in my 05 legacy gt, it require 91 from factory but it is tuned for 93.
    93 in my bike with custom power commander tune.
    But the eclipse in question will drive the same with 87 or 93. So just use 87 and save yourself some money.
    93 in my T/A
    Cheapest I can find for my DD
    White Plains, NY
    2002 Trans AM
    I use 87 with 10% seawater in my Yota
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    93 since tune. Daily driver.
    Member krese's Avatar
    Feb 2008
    Brewerton, New York
    1996 Trans AM WS6
    my 06 supercharged grand prix requires 93
    Milwaukee
    Liquid Red
    2008 Pontiac G8 GT
    My 04 maxima recommends premium for maximum performance. I don't drive my maxima to use it's full "maximum performance" so it gets regular unleaded.
    🤔 11s. blackbirdbrain89's Avatar
    hagerstown, mercersburg
    black trans am
    2000
    Quote Originally Posted by tnthub View Post
    im not looking to start a thread fight but higher cant hurt any thing other then cat,
    the higher the oct ratting the slower the fuel will burn.
    if the fire is slower the more heat can me used to push the piston down.
    if theres any fire left then it goes out the exhaust port..
    hot air flows better then cold air there for even if u have fire left after burn then it would flow better making more power.
    or thats how ive always been told.
    and a foot note lead is only used as a top end lube for the valves and things. it wont bring the oct ratting up
  1. Help: Gas ... Regular/Premium
    By lpff88 in forum General Help
    Last Post: 09-26-2008, 05:27 PM
  2. monsoon or regular?
    By NE98LS1 in forum Stereo and Electronics
    Last Post: 07-10-2007, 08:59 AM
  3. Diff. between Z06 and Regular C5
    By Corey1987 in forum Corvette
    Last Post: 01-21-2007, 05:21 PM
  4. WS6 to regular T/A
    By Crank in forum Firebird / WS6
    Last Post: 09-11-2006, 05:17 AM
  5. Regular v. Premium Gas
    By jkf243 in forum GTO
    Last Post: 06-24-2006, 03:57 PM
