Results 1 to 3 of 3
    DFW
    1999 SS
    Smoking @ WOT only Help!
    I have a '99 SS. Low mileage car, right at 28k. I am the second owner and have receipts to all the work done on the car by the previous owner. Car is from Houston, TX and all work was done at MTI in 1999. Has heads & cam, MAC headers, Borla catback, MTI Lid, LS6 intake, ported TB, etc. I bought the car about a year ago and whenever I am hard on the throttle at 4500 or above I see a good amount of what appears to be blue smoke(oil) shooting out the back. I thought that this was being caused by the PCV system and tried a catch can at first, but oil was still getting to the intake. So recently I got a valve cover breather and plugged the vaccuum port st the manifold. So essentially did a PCV delete. She is still smoking. With all the oil I cleaned out the intake after doing this, I thought for sure this would take care of it. Performance does not seem to be affected, just wondering where this would come from, other than piston rings, but has such low mileage and only smokes @ WOT. Doesn't use much oil at all in between oil changes either. Bout a half a quart. I haven't had it tuned yet for the higher elevation and less humidity of where the car is now, but could it really be causing my smoke issue? Just looking for some help and suggestons. Thanx.
    College Station TX
    2000 &2002 Z28
    all ur gaskets good? sounds like a bad oil leak
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    might be going over rich in the upper rpms.
  1. Smoking after a run
    By Lunatikgixxer in forum External Engine
    Last Post: 11-29-2011, 02:55 PM
  2. Help: Smoking!
    By WhatUpWhatUp in forum General Help
    Last Post: 06-08-2010, 11:19 AM
  3. How soon is too soon to start smoking?
    By kickflippin1 in forum Almost Anything Goes
    Last Post: 02-11-2009, 08:53 AM
  4. Smoking only @ WOT. HELP!
    By kealap in forum General Help
    Last Post: 01-11-2007, 03:39 PM
  5. last day of smoking
    By nhraformula in forum Almost Anything Goes
    Last Post: 05-08-2006, 11:29 PM
