Results 1 to 3 of 3
    Senior Member Lunatikgixxer's Avatar
    Mar 2010
    St Pete, FL
    Bat mobile black
    2000 Trans am WS6 M6
    Smoking after a run
    After i do a pass or two and let off or put it in neutral the car will smoke pretty good for a second and sometimes it will idle at like 1400rpms... What the hell is causing this.. I recently put new plugs and wires in and it cant be that. The old plugs looked burnt and were covered in oil... What are all the things that might be causing this? Its kind of annoying. Also i went to jacksonville for about 3 days for thanksgiving and when i came back and drove my car it sounds a little different with the cut out open, a little quieter. I wonder if my motor is going to blow anytime lol... I do have 127,xxx miles on it
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    sounds like youve got bad valve guides/seals.
    sohludnt blow up, but def needs some attention
    Mar 2010
    St Pete, FL
    Bat mobile black
    im pretty sure its not the valve seals... Ive had bad valve seals before and these are different symptoms..
  1. Help: Smoking!
    By WhatUpWhatUp in forum General Help
    Last Post: 06-08-2010, 11:19 AM
  2. How soon is too soon to start smoking?
    By kickflippin1 in forum Almost Anything Goes
    Last Post: 02-11-2009, 08:53 AM
  3. Smoking @ WOT only Help!
    By kealap in forum Internal Engine
    Last Post: 01-11-2007, 07:24 PM
  4. Smoking only @ WOT. HELP!
    By kealap in forum General Help
    Last Post: 01-11-2007, 03:39 PM
  5. last day of smoking
    By nhraformula in forum Almost Anything Goes
    Last Post: 05-08-2006, 11:29 PM
