Results 1 to 20 of 24
    ALBANY
    BLUE
    2000 CAMARO SS
    Best head cam package for ls1 camaro
    Looking to hit mid to high 11s with my 2000 ss camaro. Will bedoing headers no cat exhaust airlid, suspension, stickys, fast 90mm intake. Looking to spend around 2500 on a head cam package.
    Rhino21149
    Guest
    I think you will be really challenged to get into the mid 11s, maybe even noticeably below 12.0, unless you spend more or go to nitrous. I assume your $2500 is for heads and cam kit parts only. That much will buy a decent heads and cam package but not the best. You'll need really good big valve (2.08 inch intake) LS6 ported or AFR type heads and a very aggressive cam to get into decent 11-second territory, if you keep the stock displacement. IAnd I believe you will find (one way or the other) than the combination of cam and revs you need means you will have to upgrade your rockers (shaft mounted are best by far) which could cost about $80k altogether).
    You can do it easily with a 75-100 shot of nitrous added, though.
    You should aos see the driveline thread about rear axles and HP - you WILL be buying a new rear end if you do much of that.
    ALBANY
    BLUE
    2000 CAMARO SS
    Yes i know about the rearend. Yes im looking to spend around 2500 to 3 gs on just the head cam package. I know i will have to upgrade the rearend.
    Modding is an Addiction bww3588's Avatar
    Chillicothe, Ohio
    $80k? thats a lot of money.
    If you get AFR 205's ($2300.00 or so) with 10.5+:1 CR and an aggressive cam ($400.00) you could probably do it. Are you an A4 or M6, makes a difference with the cam. A4 get a good stall ($800), M6 get some gears ($500) and you should get into the 11's. My $0.02
    ALBANY
    BLUE
    2000 CAMARO SS
    Well i went with this setup. Fast 90mm intake and throttlebody, mti lid, Cartek stage 3 heads and stage 2 cam. This setup will set me into the 11s. The along with suspension and a good tune 11s are no problem.
    Quote Originally Posted by LS1POWER
    Not sure about their Stg 3 heads but most stg 3's are for stroker motors and the stg 3 will not benefit a stock ci motor like a stg 2 head. Just what I have read. Can't always believe what you read though. Got to search out the answers for yourself. I still stick with my suggestion of the AFR 205's and a decent sized cam, gears and such. What are the specs on that cam?
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    cam
    is this cam a good one to get? i have the cam and head package through slp with the ls6 intake. they say it will add 35 more horsepower, and 4 to 5 tenth in the quarter. what do you guys think can i really gain that much more? thanks in advance jeremy will this cam sound choppy?http://www.slponline.com/view_product.asp?P=51013A
    230,55,147 91Z28's Avatar
    Houston
    Cyclone Grey Metallic
    2006 GTO
    If you want mid 11s you can easily do it on stock heads. Many cam only cars have acheived 400-420rwhp and that is more than enough to run as low as 11.5. My friend only made 374rwhp in a thirdgen and ran 11.7.
    Member smokeyburnouts's Avatar
    Pittsburgh
    2002 Pontiac Trans Am WS6
    Quote Originally Posted by bww3588
    haha. thats what i was thinkin
    blownlt1
    Guest
    Just a side note on the guys that did work on my car. Currenty they have a heads and cam package making 465 rwhp. You can check out their site if you are interested. They are also doing custom turbo kits. Website is: dragonrace.com
    blownlt1
    Guest
    make sure to put the www before dragonrace. Wasn't sure if i would have been able to put that in there since I don't have 10 posts.
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    cam
    any help guys? thanks jeremy
    Bad habbit- Smoking Fords
    South Florida
    Sunset Orange Metallic
    I know you can easily get into the 11's with an AFR head and cam package for $2500. This package produces around 470 RWHP with a smallish 224/224 cam and over 500 RWHP with a bigger cam.
    2001 SS - 430 RWHP 412 RWTQ
    6 spd, FIPK, Corsa exhaust, LS7 clutch, Dart Pro PP LS1 heads, custom 220/224 cam, Kooks LT's. Ported TB, Full suspension, C5 ZO6 brake upgrade.
    LS1 is the only one...
    Wilksboro, NC
    2002 Camaro SS
    AFR heads, and T-Rex cam by Thunderracing.
    South Florida
    The T-Rex cam is designed to work only with stock heads. I have seen 415 RWHP made with that cam in an otherwise stock LS1.
    i f*****g hate rice adam0321's Avatar
    north carolina
    1999 ws6 trans-am
    where are you guys finding afr heads and cam package for 2500.00?
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    about three years ago when this thread was started.
    Feb 2008
    Missouri
    1998 Camaro Z28
    I make 380 and run 11.7 all day long. I bought my parts used though. I got about $2000 under the hood on a stock rear end
    RDU
    2002 Camaro Z28
    That TRex cam is HUGE!! would you run into big issues using that in a DD? what heads can you use with it too?
  1. Best N/A head cam package?
    By vipVEGAS in forum Internal Engine
    Last Post: 08-28-2008, 05:32 PM
  2. No head and cam package.
    By stephen02ws6 in forum Firebird / WS6
    Last Post: 04-11-2008, 11:54 AM
  3. Question: Head cam package
    By Joels1 in forum Internal Engine
    Last Post: 03-09-2008, 08:48 PM
  4. head and cam package.
    By 6sw00 in forum Internal Engine
    Last Post: 09-19-2007, 04:05 AM
  5. Head/Cam package? Hot cam?
    By white01ws6 in forum Western Members
    Last Post: 11-08-2005, 02:51 PM
