Results 1 to 11 of 11
Thread: head and cam package.
09-15-2007, 10:34 PM #1
has anybody ever seen these?? was wondering what other modifications would need to be done in order to run with this. as of now my car is stock.
http://www.lmperformance.com/5916/1.html
09-15-2007, 11:57 PM #2
i believe those heads go on a 402 so for those to work im thinking your gonna have to have the engine bored out to a 402.
09-16-2007, 02:28 PM #3
ahhh.. ok. so i guess these would be more likely to use. but in addition, what would need to be done. since i wouldnt need to bore out with this set.
http://www.lmperformance.com/5910/1.html
09-16-2007, 04:59 PM #4
AFRs are great heads but there are cheaper ways to go. Texas Speeds PRC LS6 heads give great results for about $1000 less. TS also has many more cams to choose from. Either way not a bad kit there. You're gonna want some long tube headers and a dyno tune from a good shop. This article will tell you everything else you need.
http://ls1howto.com/index.php?article=2
09-16-2007, 05:32 PM #5
wow.. i dont think ill be able to do the swap myself.. look a little bit technical. is it manditory that i get a new intake manifold for the swap? or is it just common sense to do it while ur there..
09-16-2007, 06:10 PM #6
No not mandatory. Reread the article a few times, may seem easier then.
09-16-2007, 09:03 PM #7
wow.. how come heads alone are the price of the package that i saw??
09-18-2007, 08:55 AM #8Junior Member
- Apr 2006
- MINNESOTA
BLUE- 2000 SS CAMARO
That LS1 how to article was written along time ago, stuff was more expensive then.
FWIW, 99% of the time you get what you pay for in aftermarket parts. If someone wanted to go buy my heads they better bring about $6k++ with them. It all depends on the application and what you want out of the car. You can spend as little or as much as you want.
09-18-2007, 08:56 AM #9Junior Member
- Apr 2006
- MINNESOTA
FWIW, the heads are the same in those two links, the cams are the difference.
09-18-2007, 05:30 PM #10
got ya.. so you dont think its a good buy for 3k?
09-19-2007, 04:05 AM #11Junior Member
- Apr 2006
- MINNESOTA
Well, AFR heads are AFR heads, no matter where you get them and a cam is usually around $400 (just for the cam).
Personally I would go with the 205's instead of the 225's listed. They will be better overall on a stock CI motor. I know if you look around you can get them for around $2300 and when you add a cam to that you come up with $2700.
http://cgi.ebay.com/ebaymotors/AFR-C...spagenameZWDVW
Voila!!
best head and cam package
By barryz in forum Internal EngineReplies: 9Last Post: 02-05-2013, 03:22 PM -
Question: Head cam package
By Joels1 in forum Internal EngineReplies: 0Last Post: 03-09-2008, 08:48 PM -
Head/cam package...
By konigandy6 in forum Internal EngineReplies: 3Last Post: 02-27-2008, 10:41 AM -
LS1 Head & CAM Package
By tommyjt2006 in forum Parts For Sale / TradeReplies: 4Last Post: 03-28-2007, 06:50 AM
