01-04-2007, 07:23 PM #1
Need help on how to by pass the image in a in-dash dvd player head unit install!
my brother installed my clarion in-dash dvd palyer. only problem is how do you by pass the e-brake? We are trying to get the dvd image to stay on while the car is motion anybody know?
01-04-2007, 08:20 PM #2Compulsive F bomb dropper
- Apr 2006
- yuma arizona
silver- 1998 Z28
usually have to ground out the pink wire. check the manual. it may require a "brake sequence" i.e. on, off, on. or off, pause, on. etc... if that's the case, wire a toggle to it to give it that "sequence"
01-05-2007, 01:13 PM #3Member
- LA
Grey- 2010 Camaro 2SS/RS CGM
find out which wire is for the e-brake, then splice a wire off the amp turn on wire and wire both to a switch, that way you can have it on when you drive and if it requires a sequence then you have a switch to turn it on and off.
01-05-2007, 03:25 PM #4Junior Member
- Sep 2005
- Lancaster, CAlifornia
Dark Green- 1994 Camaro
get a simple toggle switch, you can use one from a car alarm. There should be two sides of the switch that you can connect wires too. Solder the green wire to one side and then solder another wire to the other side and connect that to the chassis. the toggles switch acts as your 'ebrake'.
12-23-2009, 11:18 AM #5
you cant just ground the wire?
12-23-2009, 04:02 PM #6
DO a search on google and see if you can find the overide code. I did this for a friends Jenson in dash and you have to enter it with remote but never needs a e-brake sequence again.
Head Unit install in pics
By sjsingle1 in forum Stereo and ElectronicsReplies: 69Last Post: 03-05-2016, 11:37 PM -
Stock Head Unit System or install custom head unit?
By ibh182 in forum Stereo and ElectronicsReplies: 3Last Post: 06-16-2007, 09:43 AM -
nbm pass fender cd player, chrome zr1's (2), tan door panel pass
By 1fastcamarosss11 in forum Parts Wanted / TradeReplies: 12Last Post: 02-17-2007, 09:47 AM -
WTB: monsoon head unit (cd player)
By roliath in forum Parts Wanted / TradeReplies: 1Last Post: 07-15-2006, 05:09 PM -
speedometer not working after head unit install???
By MHarvey in forum Stereo and ElectronicsReplies: 2Last Post: 03-03-2006, 06:55 PM
