Results 1 to 20 of 70
Thread: Head Unit install in pics
03-12-2011, 07:40 PM #1Senior Member
- Jan 2010
- texas
silver- 2000 formula
Cant believe there is not a guide on here already......being a TECH TEAM member.....I will just have to fix that
got a alpine CDA 9887 new from amazon.......they dont make this bad boy any more ...... I got it especially for its IMPRINT feature.......its a feature which will compensate for the acoustics in your car environment.....to use it you need a separate kit to implement it......which includes software and a special microphone.....i cant afford it right now so its on the back burner
a few items will help for a install.....these are METRA items i got from amazon also
99-3009 faceplate kit
40-GM10 antenna adapter
70-1858 wire harness adapter
and a AXXESS universal adapter for the steering wheel controls.....from amazon also
follow alongLast edited by sjsingle1; 03-13-2011 at 12:06 AM.
03-12-2011, 07:41 PM #2Senior Member
- Jan 2010
- texas
03-12-2011, 07:41 PM #3Senior Member
- Jan 2010
- texas
metra piecesLast edited by sjsingle1; 03-12-2011 at 07:51 PM.
03-12-2011, 07:41 PM #4Senior Member
- Jan 2010
- texas
even has a remote for the alpine HULast edited by sjsingle1; 03-12-2011 at 07:52 PM.
03-12-2011, 07:42 PM #5Senior Member
- Jan 2010
- texas
3 bolts hold the radio in......7mmLast edited by sjsingle1; 03-12-2011 at 07:52 PM.
03-12-2011, 07:42 PM #6Senior Member
- Jan 2010
- texas
03-12-2011, 07:43 PM #7Senior Member
- Jan 2010
- texas
03-12-2011, 07:43 PM #8Senior Member
- Jan 2010
- texas
these clips hold the radio bezel cover on.....had to stick a finger nail file under it to pry it offLast edited by sjsingle1; 03-12-2011 at 07:53 PM.
03-12-2011, 07:44 PM #9Senior Member
- Jan 2010
- texas
out with the oldLast edited by sjsingle1; 03-12-2011 at 07:53 PM.
03-12-2011, 07:44 PM #10Senior Member
- Jan 2010
- texas
the wire harness was a PITA to get off....had to reach under by the glove box to get the left hand harness loose ...then you can pull it out a little more to get the main harnessLast edited by sjsingle1; 03-12-2011 at 07:56 PM.
03-12-2011, 07:45 PM #11Senior Member
- Jan 2010
- texas
the nub on the back of the radio fits into that hole in the back of the dash.....had to cut it off and unbolt the metal bracket that is attached to it........the alpine was a hair longer that the stock radio and hit itLast edited by sjsingle1; 03-12-2011 at 08:11 PM.
03-12-2011, 07:45 PM #12Senior Member
- Jan 2010
- texas
you can see why you need a adapter on the antenna .....its really short and will not fit into conventional antenna receptaclesLast edited by sjsingle1; 03-12-2011 at 07:59 PM.
03-12-2011, 07:46 PM #13Senior Member
- Jan 2010
- texas
i cut the plastic part of the dash and all that is left is the metal bracket.....the foam is leftover from my intake gasket kit and did nicely to help prop up the stereoLast edited by sjsingle1; 03-12-2011 at 08:00 PM.
03-12-2011, 07:46 PM #14**Te@M fBoDy**
- Nov 2010
- The Woodlands,Texas...N.O.
Pewter Metallic- 2000 Pontiac Trans Am WS6
how much do you want to sell the stock radio for?
03-12-2011, 07:46 PM #15Senior Member
- Jan 2010
- texas
hooked up the METRA harness to the alpine harness.......used red POSI LOCKS..........those things sure are niceLast edited by sjsingle1; 03-12-2011 at 08:02 PM.
03-12-2011, 07:47 PM #16Senior Member
- Jan 2010
- texas
you have to trim the METRA face plate for it to fitLast edited by sjsingle1; 03-12-2011 at 08:03 PM.
03-12-2011, 07:47 PM #17Senior Member
- Jan 2010
- texas
03-12-2011, 07:48 PM #18Senior Member
- Jan 2010
- texas
the AXXESS adapter ....its light weight and very smallLast edited by sjsingle1; 03-12-2011 at 08:05 PM.
03-12-2011, 07:48 PM #19Senior Member
- Jan 2010
- texas
the mini plug fits into the back of the alpine HU and relays the steering wheel control signalsLast edited by sjsingle1; 03-12-2011 at 08:13 PM.
03-12-2011, 07:49 PM #20Senior Member
- Jan 2010
- texas
have to separate the steering wheel control wire from the GM harness to wire it up to the AXXESS unitLast edited by sjsingle1; 03-13-2011 at 12:08 AM.
Head Unit
By jetaws6 in forum Stereo and ElectronicsReplies: 4Last Post: 10-03-2010, 10:35 AM -
Need help on how to by pass the image in a in-dash dvd player head unit install!
By 01SOMSS! in forum Stereo and ElectronicsReplies: 5Last Post: 12-23-2009, 04:02 PM -
Stock Head Unit System or install custom head unit?
By ibh182 in forum Stereo and ElectronicsReplies: 3Last Post: 06-16-2007, 09:43 AM -
Kenwood Head Unit For Sale(Pics)
By strapp in forum Parts For Sale / TradeReplies: 0Last Post: 05-06-2006, 01:40 PM -
speedometer not working after head unit install???
By MHarvey in forum Stereo and ElectronicsReplies: 2Last Post: 03-03-2006, 06:55 PM
