Results 1 to 2 of 2
Thread: cometic phuzion head gaskets
01-03-2007, 04:44 PM #1
http://www.cometic.com/phuzion.aspx
The gas filled o-ring portion of Phuzion is manufactured from high strength aerospace tubing capable of withstanding ultra high combustion temperatures and pressures. Additionally each ring is plated with silver to increase the sealing level and minimize brinelling. The silver also aids in withstanding head to block movements without burnishing the surfaces. The real innovation to the gas filled o-ring though, is the gas itself. During the manufacturing process the gas in the ring is sealed in at 500-600 psi at room temperature. As the engine is warmed up, the gas is heated increasing the pressure inside the ring causing it to expand. This allows the ring to seal the combustion even in the event of head liftoff.
The MLS gasket portion of Phuzion is what gives you the ability to use the gas filled o-rings without machining any grooves in your block and/or head. MLS head gaskets are comprised of three layers. Viton coated embossed spring steel outer layers and a steel inner layer, which provides support and thickness to the gasket. Embossments on the MLS gasket allow for proper seal around oil and water passages.
Phuzion Requirements: Head and Deck surfaces should be within .002” of flatness and have a surface finish of 50RA or finer. The compressed operating thickness of Phuzion is .051”.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
01-03-2007, 05:45 PM #2
a bit on the pricey side. most of us dont make the power for them to be needed but i suppose it could be worth it
For Sale: New Cometic LS1 Head Gaskets 3.91 @ .040
By GTO1_OHIO in forum Parts For Sale / TradeReplies: 0Last Post: 05-02-2010, 07:09 AM -
Question: Head gaskets
By tthrash in forum Internal EngineReplies: 4Last Post: 11-30-2009, 09:08 AM -
Cometic Phuzion Cylinder Head Gasket - In-Phuzion
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 09-29-2007, 06:50 AM -
Cometic head gaskets... .040 vs. .045
By silverTA2002 in forum Internal EngineReplies: 5Last Post: 10-01-2005, 01:43 PM -
f/s AFR 205cc, head gaskets, and head bolts
By slimeball6969 in forum Parts For Sale / TradeReplies: 1Last Post: 08-12-2005, 09:17 PM
