    Member silverTA2002's Avatar
    Bradenton, FL
    2002 Pontiac Trans Am
    Cometic head gaskets... .040 vs. .045
    I just got my heads cam package in the mail today.
    TEA 1.5 5.3 heads milled less than .005
    Comp cams 220/224 .581 114lsa +2
    Trick flow chromoly hardened pushrods (7.4)
    Cometic head gasket .040
    I was wondering if this was the right gasket. Most people seem to be using .045. What difference will it make?
    2002 Trans Am 6sp, SLP lid, Holley filter, Shaner S3 TB, Jet Hot long tubes and cats, FRA, HP tuners, Hotchkis STB and LCAs. TEA stage 1.5 5.3 heads, Comp 220/224 114 +2, UMI Boxed SFCs, Edelbrock PHR. Moser 9" 4.11 gears.
    **FOR SALE**: http://www.ls1.com/forums/showthread.php?t=60478
    Bradenton, FL
    Also what will my compression ratio and P/V clearance be?
    This is for a daily driver.
    Will I be better off mailing those back and getting GM gaskets locally?
    Stratford, NJ
    Fire Red
    2000 ws6 #599 9/20/1999
    you can download a compression ratio calculator online, if you want pm me and i'll give you the site. further more, your headgasket thickness plays a major factor in your compression ratio. more compression can equal more power. a lot comes into play with that though. anyway. figure out your compression. get a good set of sce gaskets at the thickness you need and have fun. the sce titans are the best i've seen but they're pricey and may be overkill for your needs. i'm not familiar with cometic headgaskets so someone else will have to chime in to tell you if they're good or not.
    WALLst AL
    Guest
    The .040 will give you a little higher compression over the .045. Cometic gasket can be reused and they have a tighter squench than the GM gaskets.
    Since I milled .040, I went with the thicker .045.
    You can figure your compression ratio here
    c5frc.com/calculators/Compression_Ratio_Calculator.htm
    Bradenton, FL
    Well, I kept them, Install went great, car runs perfectly fine on 93 octane with my 11.3 to 1 compression.
    I'm very happy so far. Under 2k, it's just like stock, above it, the car really wants to take off.
    WALLst AL
    Guest
    Quote Originally Posted by silverTA2002
    cool
  1. Question: head gaskets
    By 99ss in forum External Engine
    Last Post: 05-19-2010, 11:32 PM
  2. For Sale: New Cometic LS1 Head Gaskets 3.91 @ .040
    By GTO1_OHIO in forum Parts For Sale / Trade
    Last Post: 05-02-2010, 07:09 AM
  3. Cometic Phuzion Cylinder Head Gasket - In-Phuzion
    Last Post: 09-29-2007, 06:50 AM
  4. cometic phuzion head gaskets
    By mrr23 in forum Internal Engine
    Last Post: 01-03-2007, 05:45 PM
  5. f/s AFR 205cc, head gaskets, and head bolts
    By slimeball6969 in forum Parts For Sale / Trade
    Last Post: 08-12-2005, 09:17 PM
