Results 1 to 2 of 2
Thread: Suggestions? Cams/heads/rockers
12-24-2006, 09:03 AM #1Junior Member
- Sep 2006
- Houston
White- 2000 Trans Am
Hello all, I have a 2000 Trans AM that is stock right now. I just bought some long tube headers and while they were pulling up everything I thought it would be a good time to upgrade the rest. I am going to install the LS6 intake on this as well. I also want to upgrade the heads, cams, and rockers as well to finish it off down there. Just curious on this ad if this should work with my LS1 Trans Am:
LS1 / LS6 Ported Heads, Cam, Shaft Rockers
This is a set of LS6 Style heads CNC Ported by Patriot Performance. Stage II 59cc Chambers, 2.02 int 1.57ex Stainless valves with under cut heads, 225cc int 83cc ex Runners, Comp Cams Dual .650 lift springs with titanium retainers, magnesium bronze intake guides, phosphorus bronze exhaust guides 5 angle machined hardened seats. For center bolt valve covers. Ideal for 346 to 382 cid engines with 2200-6000 RPM power band. We’ve used this set up on a stock bottom ended LS1 and made 580 HP at 6200 RPM. This also includes a Lunati Hyd Roller Cam (See specs in photo) plus Patriot Performance Shaft mount roller Rocker Arm Kit which are made from 6061 Aluminum. The 1.7 ratio rocker arms can handle aggressive hydraulic or solid roller cams ( require a valve cover spacer for clearance)
Will this work with my stock trans am, just wanted to make sure before I bought it. Also what kind of horsepower can you expect from this setup, also adding the LS6 intake and Longtube headers as well?
12-24-2006, 09:08 AM #2member since may 2000
- Dec 2002
- n/w chicago
whats the cam specs.
long tubes, heads and cam will get you a 100 rear whell horsepower bump and more depending on cam.2000 nhra edition formula
a few bolt ons, 379 rwhp
11.96 @113.25
Chevy 496 Comp Cams Roller Rockers & Valvespring U
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 01-11-2010, 09:40 AM -
MDS Ignition, Comp Cams Roller Rockers & Holley Ca
By Ed Blown Vert in forum Camaro / SSReplies: 2Last Post: 08-05-2009, 10:08 AM -
Comp Cams Ultra-Gold Roller Rockers Install - CHP
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 01-05-2009, 09:50 PM -
Comp Cams Roller Rockers: Noise?
By Three cams short in forum Internal EngineReplies: 5Last Post: 11-04-2005, 03:42 AM -
Crane Cams 1.8 LS1 Rockers
By WS SICK in forum Parts For Sale / TradeReplies: 1Last Post: 08-15-2005, 05:19 PM
