Results 1 to 1 of 1
01-11-2010, 09:40 AM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Chevy 496 Comp Cams Roller Rockers & Valvespring U
Chevy 496 Comp Cams Roller Rockers & Valvespring Upgrade - The Sweet Spot
While on paper our Boulevard Bruiser ("Ground & Pound," October '09) seemed well at home in the upper rpm. A closer look revealed a less-than satisfactory issue with valve float and subsequently a loss in power.While on paper our Boulevard Bruiser ("Ground & Pound," October '09) seemed well at home in the upper rpm. A closer look revealed a less-than satisfactory issue with valve float and subsequently a loss in power. It's been known that the more cubic inches the more difficult it is to spin that reciprocating mass at high rpm. Yet, with the availability of off-the-shelf items such as lightweight and higher tolerance valvetrain components, the ability to wring out even more power is also available with the right combination.inline_mediumwraptextright26115125/tech/engines_drivetrain/cams_heads_valvetrain/1002chp_chevy_496_comp_cams_roller_rockers_valvesp ring_upgrade1002chp_01_z+chevy_496_comp_cams_rolle r_rockers_valvespring_upgrade+performance_engine_p arts.jpgTrue
Photo Gallery: Chevy 496 Comp Cams Roller Rockers & Valvespring Upgrade - Chevy High Performance Magazine
More...
COMP Cams LS Valvespring Compressor - Tool Bin
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 06-18-2011, 02:20 AM -
MDS Ignition, Comp Cams Roller Rockers & Holley Ca
By Ed Blown Vert in forum Camaro / SSReplies: 2Last Post: 08-05-2009, 10:08 AM -
Comp Cams Ultra-Gold Roller Rockers Install - CHP
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 01-05-2009, 09:50 PM -
LS1 Comp Cams Hydraulic Roller Camshaft Upgrade -
By Ed Blown Vert in forum Camaro / SSReplies: 2Last Post: 01-01-2009, 04:17 PM -
Comp Cams Roller Rockers: Noise?
By Three cams short in forum Internal EngineReplies: 5Last Post: 11-04-2005, 03:42 AM
