Thread: Rocker Arms
12-20-2006, 02:06 AM #1
Rocker Arms
Allright well Im getting ready to purchase the PRC LS6 CNC Heads from Texas-Speed and would like to change out the rocker arms and lifter while im at it. I was thinking about the comp cams pro-magnum roller rocker arm kit and the comp cams ls1 gen 3 solid roller lifters that texas-speed also offers. Any other opinions out there? Thanks
MS4 Camshaft, Doulble Valvespring, Chrom Moly Hardened Push Rods, QTP LT Headers, 3" Custom Strait Pipes w/ Single Chamber Flowmasters Dumped,
!AIR, !EGR, !CAGS
12-20-2006, 05:29 AM #2
are you going to solid roller camhaft?
12-20-2006, 12:44 PM #3
no im keeping the ms4
12-20-2006, 12:56 PM #4Member
- Nov 2006
- New Jersey
Sunset Orange Metallic-M6- 2002 Pontiac Trans Am WS6
B.A.N.A.T.A. -- does it stand for BAD ASS NATURALLY ASPIRATED TRANS AM? just a guess
12-20-2006, 01:31 PM #5
Well, if your keeping a hydraulic cam, you'll want hydraulic lifters, not solid roller lifters.
12-20-2006, 04:18 PM #6
I would say unless your runnin a clutch car there would no benefit to the solid lift cam. Yes it will give you a higher rpm window of power band and you can run a MUCH more agressive grind but you also need to take into consideration that you'll need more spring pressure and it puts more wear and tear on all components.
If the heads you purchased came with a flow# from the flow bench I would get a custom ground cam to match your head #'s and weight,gears,and comp. to match your exact combo.
Not an off the shelf grind!!!!
12-20-2006, 09:41 PM #7
thanks for the info blacklt1z28. i didnt even think about that. and yeah b.a.n.a.t.a. stands for bad ass naturally aspirated trans am. i though it was cool.
High-Ratio Rocker Arms - Off Your Rocker
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 08-19-2011, 02:50 PM -
Question: rocker arms
By william45 in forum General HelpReplies: 1Last Post: 07-02-2010, 02:13 PM -
Help: rocker arms ???
By ggino85 in forum Internal EngineReplies: 7Last Post: 08-24-2008, 08:08 AM -
rocker arms
By 94z28l in forum Internal EngineReplies: 11Last Post: 05-30-2007, 11:22 PM -
slp 1.85 rocker arms
By nhraformula in forum Parts ReviewReplies: 4Last Post: 08-13-2005, 01:31 PM
