Thread: rocker arms ???
    caraholic ggino85's Avatar
    most miserable city in the US
    blue green chameleon
    rocker arms ???
    im tightening the rocker arms after installing hardened pushrods and i noticed that the rocker arms donts sit center on the valvespring, they are a little off. is that normal??
    come on guys, my engines all taken apart and i need an answer so i can finish, please
    Texas, USA
    2000 Camaro
    mine do the same thing...you could buy some pushrod guide plates to straighten them out but i think it is pretty normal to have that kind of play in it
    RI
    Mag Red
    2002 Vette
    I assume you mean side to side. There is some slop in the bearings that will allow this. Make sure you use the correct tightening procedure. If you just installed a cam, make sure you check geometry.
    and here i was just thinking i could tigthten them to 22 lbs ft, (or 264 lbs inches) and be done with it. i didnt think i had to do it in any specific order
    do i have to have the #1 piston in tdc before tightening the rockers, i dont have a socket big enought to fit over the crankcase bolt to turn the damn thing to tdc, and i really dont wanna walk to autozone to buy one, its 8am here and everyone i know is eithier asleep or at work.
    Texas, USA
    2000 Camaro
    yes other wise your when you torque the rocker arms some of them will have pressure from the valvesprings and you wont be torquing it as much as you think
    sucks but thats what you have to do
    Marylandistan
    2001 Trans Am (sold)
    Quote Originally Posted by ggino85 View Post
    All I ever do with mine is torque em to 22ft lbs. I spin mine to 6,800 or so and never had a problem.
  1. High-Ratio Rocker Arms - Off Your Rocker
    Last Post: 08-19-2011, 03:50 PM
  2. Question: rocker arms
    By william45 in forum General Help
    Last Post: 07-02-2010, 03:13 PM
  3. rocker arms
    By 94z28l in forum Internal Engine
    Last Post: 05-31-2007, 12:22 AM
  4. rocker arms
    By C5_LS1 in forum Corvette
    Last Post: 03-10-2006, 11:59 AM
  5. slp 1.85 rocker arms
    By nhraformula in forum Parts Review
    Last Post: 08-13-2005, 02:31 PM
