Results 1 to 10 of 10
    Member Doom's Avatar
    NJ
    89 BII, 02 SS
    2 quick questions
    I was wondering, just how good are a set of Pacesetter longtube headers? Non-ceramic coat black painted ones that run about $230-$240 bucks.
    Also, I wanted to know how much the stock rear can take before it needs to be replaced ?
    Lost in Texas
    Custom Slate Blue
    99 B4C
    pacesetter makes good headers. Living in NJ you don't want plain black ones, you want coated cause they WILL rust in a few years if not coated.
    How well the rear will hold up is dependent on alot of things. On street tires, it will last longer than with DRs. In an automatic it will almost always handle tons more power than a 6-speed.
    NJ
    89 BII, 02 SS
    Hmm.. In that case, what would be the best ceramic coat headers for my $$$? Should I still go with Pacesetter or would another brand be better ?
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    What is the car......? NEED MORE INFO!!!!
    Clutch .......... Auto How many miles.... etc.
    IMO it's hard to beat coated pacesetters for the price. Are there better headers out there? Yep, but for the money I'd buy another set of pacesetters. I've got a couple of years on mine with zero complaints and they still look brand new.
    NJ
    89 BII, 02 SS
    Quote Originally Posted by LS2Tuner View Post
    Well im getting the car this Saturday, it will either be 80k miles or 40k miles depending on which one i pick an both are m6 ls1 camaros
    Bragg NC
    Met. Sunset Orange
    01 SS
    I also agree with above i have had my pacesetters for a while now and so far so good. they look great and hold up well. The only issue i have had was the header bolts rusting but just dont used the supply'd bolts and you will be good. also keep in mind if you go ory then you will have too fix the y pipe so it doesnt abuse your floor board.
    Stock rear ends in a 6spd can break under stock hp. Depending on what upgrades you plan on doing too the car keep in mind the rear end is the weak spot on these cars.
    J
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by Doom View Post
    40,000 looks alot better!!! Unless you know how those 80,000 were driven!!!
    You can get away with about 575-625hp on that rear as long as your not coming out the gate at 6000rpm.
    NJ
    89 BII, 02 SS
    haha i definitely wouldn't launch higher than 4000~4500.. the car with 80k is sold so the 40k is my only option now. I keep hearing different things about the rear though, my goal is like about 500rwhp. I think im going to have to upgrade the rear for that ?
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    You won't be launching higher than 2500 rpm with a stock set-up unless you plan on annihalating the tires. 4-5,000 an you will simply sit and spin, fun but not fast.
  1. got a few quick questions
    By amitc31100 in forum Internal Engine
    Last Post: 04-19-2007, 08:33 PM
  2. Quick Stupid Questions
    By Mr. CarelessAndImprudent in forum Almost Anything Goes
    Last Post: 12-15-2006, 12:00 AM
  3. QUICK HELP! Slave cyl questions
    By jtramo in forum General Help
    Last Post: 11-24-2006, 10:51 AM
  4. Replies: 4
    Last Post: 09-21-2006, 02:31 PM
  5. 2 quick questions
    By FISH 99 WS6 in forum General Help
    Last Post: 05-08-2006, 03:03 PM
