Results 1 to 3 of 3
    OH
    1999 Pontiac Trams Am WS6
    2 quick questions
    My low coolant light is on but level is fine. How do I get it off? Should I change it? Second, my brake light on dash doesn't come on anymore while the e-brake is used. How do I fix that?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    the low coolant sensor most likely needs replacing. it's on the radiator just below the cap about 3" down. has a clip you'll have to pry off and then it'll pop right out. then, you just push the new one on and it'll snap into place. reattach the wiring harness and you're done.
    brake light could either be the bulb in the dash or the switch down on the e-brake handle isn't working.
    OH
    I'll check it out, thanks.
  1. got a few quick questions
    By amitc31100 in forum Internal Engine
    Last Post: 04-19-2007, 08:33 PM
  2. 2 quick questions
    By Doom in forum General Help
    Last Post: 12-21-2006, 07:28 PM
  3. Quick Stupid Questions
    By Mr. CarelessAndImprudent in forum Almost Anything Goes
    Last Post: 12-15-2006, 12:00 AM
  4. QUICK HELP! Slave cyl questions
    By jtramo in forum General Help
    Last Post: 11-24-2006, 10:51 AM
  5. Replies: 4
    Last Post: 09-21-2006, 02:31 PM
