Thread: wheel size
    florida
    2002ss
    wheel size
    Is it possible to put a 18 x 9 wheel with stock offset using a 265/40/18 tire on a stock suspension 2002ss. This will be going on the front or will there be rubbing issues. Thanks
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    it will fit. 18 x 9 with about 50-55mm offset.
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    no problem... but remember that the tire will be taller than stock.
    ideally, you'd want 275/35-18 on them.
    Eugenio_SS
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Quote Originally Posted by Eugenio_SS View Post
    I agree there should be no clearance issues with 275/35's.
    florida
    2002ss
    The reason I ask is I don't like the way a 35 series tire looks on a fbody unless the car is lowered. I don't want to lower the car since my neighborhood has speed bumps every 100ft or so. This would also let me by a small bit get rid of some of that 4 x 4 look. Still looking for any problems that would arise. Thanks
    Jun 2002
    Montreal, CANADA
    triple-black
    remember that the 35 is the percentage of wall height relative to tire width.
    The overal diameter of a 17" w/ 275/40-17 is same as a 18" w/ 275/35-18
    you are sacrificing 1" of tire wall for 1" of rim.
    Having a 275/40-18 will have the same sidewall height, but the whole Overall Diameter would be increased by that 1"
    orlando, fl
    2014 camaro 2ss/rs
    that's what he is wanting. to take up the fenderwell clearance between the tire and fenderwell. there may, or may not be rubbing at full lock.
    Member ProwlerZ's Avatar
    Myrtle Beach
    2002 Z28
    I'd have to say that it will rub at full lock. I've got 255/35/18s on a 9.5" rim, and it rubs at full lock. Go to work on the fenders with a hammer and you can fix it, at least I could. I agree with the fender well gap though, I can't lower my car because of the conflict between LTs/Duals and SC roads, so I just stuffer 295/45/18s out back and I'm going to put 245/50/18s up front, then drop the front by 1-1.5". It's going to give the car a vintage slant to it, like it's got slicks on it, but I think it's the only option other than 2k worth of Air-bags and mediocre handling.
    She's baaaaaccccck...
    '02 Z/28 M6 Hardtop
  1. Question: What size wheel studs? OEM size?
    By x10-wakerider in forum Wheels and Tires
    Last Post: 06-20-2009, 08:26 AM
  2. wheel size
    By TmaxicanA in forum Wheels and Tires
    Last Post: 03-30-2008, 07:24 PM
  3. wheel size?
    By 1fastgto in forum GTO
    Last Post: 04-20-2007, 09:38 PM
  4. Wheel size of 95 z28
    By zbizkit in forum Wheels and Tires
    Last Post: 02-19-2007, 10:44 AM
  5. Wheel Size
    By bkdmnd in forum Wheels and Tires
    Last Post: 02-19-2007, 06:32 AM
