Thread: wheel size
    SAN FRAN SISCO BABY
    VW BEETLE W/ FLOWER
    88 CRX
    wheel size
    I am wanting to et some 15" rims for some drag radials ..ca anyone tell me the off set you need? I think the size I need is 15"x10 and anyone know a good place to find some real cheap
    Member WS6ICK2K's Avatar
    Jan 2008
    Pittsboro NC
    Metallic Blue
    2000 Trans Am WS6
    I think you have to shave the brake calipers to make 15s fit on an f body. Not sure about which ones though.
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    i'd recommend against a wheel that makes you gring the calipers, if you're using the car on the street.
    Eugenio_SS
    Drag racing is a disease! RacerBob's Avatar
    Feb 2008
    Youngstown, Ohio
    Maroon
    2000 Z28
    Sorry, I can't help with the off set.
    To keep from having to grind the calipers, go with Greg Weld Wheels. They will clear. Not sure if the 10" wide wheels have hit the market yet, you'll have to check stock once you get the correct offset.
    Here is the link to his site:
    http://www.gregweld.com/brands/styles/?bid=2
    Drag racing...just another numbers game.
    Vortech Super Charger, 9" w/4.11, 3200 Stall, BMR SFC, BMR TracPak, !MAF screen, 160 T-Stat.
    SAN FRAN SISCO BABY
    VW BEETLE W/ FLOWER
    88 CRX
    thanks for al the info..mr. lous gave me some advice aswell and said greg weld to...so ill check them out..and looks like ill have to settle for 16" I dont want to grind on my street car the offset was 7.5" and google converted it to 190 mm ..not 100% sure that's right but that's what google told me lol
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    15 x 3.5" Weld Racing Draglites
    165R15 Radial Tires
    15 x 10 7.5" backspacing Weld Racing Draglites
    275/50-15 Mickey Thompson ET Street Drag Radials
    and lots of grinding to get them to clear the rear calipers. i drive mine every day. scroll to the bottom to see the calipers
    http://www.stealthram.com/wheels.htm
    SAN FRAN SISCO BABY
    VW BEETLE W/ FLOWER
    88 CRX
    hey thanks for that info and the pics
    orlando, fl
    2014 camaro 2ss/rs
    no problem
  1. Question: wheel size
    By reaper ws6 in forum Wheels and Tires
    Last Post: 10-02-2011, 02:37 PM
  2. Question: What size wheel studs? OEM size?
    By x10-wakerider in forum Wheels and Tires
    Last Post: 06-20-2009, 08:26 AM
  3. wheel size?
    By 1fastgto in forum GTO
    Last Post: 04-20-2007, 09:38 PM
  4. Wheel size of 95 z28
    By zbizkit in forum Wheels and Tires
    Last Post: 02-19-2007, 10:44 AM
  5. Wheel Size
    By bkdmnd in forum Wheels and Tires
    Last Post: 02-19-2007, 06:32 AM
