Thread: Putting in aftermarket speakers
12-08-2006, 07:18 PM #1Junior Member
- Oct 2006
- Maryland
Mistic Teal- 1998 Formula
The speakers back seat panels of my '98 formula with the monsoon system are blown. I want to replace them with a set of Sony Xplode speakers they were cheap, and it was 2a.m when I decided I was going to put speakers in), but the wireing has me stumped. Should I just splice the 4 wires from the car into 2 for the speaker? Or are two for an amp on the speaker? Also, what size are the speakers in the hatch area?
12-08-2006, 11:14 PM #2
post this into the stereo and electronics area. You'll get way more help there. I do know it's not as simple as just throwing some different speakers in there because the stockers are 2 ohm speakers. The sails are 6" and I *think* the subs are also but not positive on that.
12-09-2006, 11:38 AM #3Member
- Oct 2006
- Florida
Navy Blue Metallic- 2002 Trans Am WS6
also, if you have the monsoon system, the rear panel speakers only receive low frequencies. do not buy a full range speaker and put it in, because the mids and tweeters will not work unless you bypass the factory amp. I would go with a set of kicker 6 inch or get a component system.
12-09-2006, 01:27 PM #4
most places will sell a speaker adapting clip. Go to a stereo shop and check. The rears are 6.5", fronts are 6.5"s with a tween pod. Rear is a combination 4" and something else but you're able to use a 6x9
12-09-2006, 09:43 PM #5Junior Member
- Oct 2006
- Maryland
Alrigh. Thanx for the advice.
Question: Problems With Aftermarket Sail Panel Speakers (4Th Gens)
By fbodyNATION in forum Stereo and ElectronicsReplies: 8Last Post: 10-09-2011, 04:48 AM -
Wiring in new speakers directly to aftermarket head unit
By 99bluebird in forum Stereo and ElectronicsReplies: 4Last Post: 10-26-2007, 10:36 AM -
Installing aftermarket speakers
By Skitzo Gryphon in forum Stereo and ElectronicsReplies: 3Last Post: 12-10-2006, 12:05 PM -
Help Aftermarket Sail Panel Speakers Sound Terrible.
By 99BlueTA in forum Stereo and ElectronicsReplies: 4Last Post: 12-18-2005, 08:51 PM -
hooking up speakers to aftermarket headunit
By Orange99z28 in forum Stereo and ElectronicsReplies: 7Last Post: 08-29-2005, 11:31 AM
