    Member Orange99z28's Avatar
    joliet il
    orange
    99 z28
    hooking up speakers to aftermarket headunit
    i got a new head unit and harness, apparently theres an amp somewhere? its monsoon by the way. the 2 front speakers have four wires to each, and the back 2 have 2 to each (i'm pretty sure there was supposed to be four?) where exactly is the amp at and how do i bypass it?, or is there an easier way of changing the ohms? please help
    MEMBER 5150's Avatar
    Visalia Cali
    SILVER
    2000 Z/28
    i just put a complete system in mine, didnt run across any amps except for the two i put in back. i ran all new 14 guage wiring to the speakers, that might be the easiest thing for u to do.
    Rock-n-Roller White Rascal's Avatar
    OHIO Go Buckeyes!
    '07 Trailblazer LT
    The POS Monsoon amp is located above the rear wheel on the passenger side of the car in front of the spare tire. It's mounted to a plastic plate and is on the fender side of the plate. Bypass the amp by running all new speaker wires from your new HU. The factory wires aren't worth using. You'll want to replace the speakers because I don't know of any HU's that can power the factory 2 ohm speakers
    The front speakers are passively bi-amped. The HU powers the 4 ohm tweets and the POS Monsoon amp powers the 2 ohm mid-woofers. Firebirds have subwoofers in the B-pillars with dual 4 ohm voice coils ran in parallel. Camaros only have single 2 ohm voice coil subs.
    The White Rascal SOLD
    Crank up the drums, crank up the bass,
    Crank up my Les Paul in your face!
    joliet il
    orange
    99 z28
    thanks, looks like i got a bit of work ahead of me though.
    completely off-topic, but do i have to add anything to my paint before i paint the car (cause of plasctic and fiberglass)? i'm using acrylic laquer with pearl in it, thanks again
    2000 WS-6
    if your amps not bad, i wouldnt replace it, just intergrate it.
    OHIO Go Buckeyes!
    '07 Trailblazer LT
    Quote Originally Posted by tamu130
    The factory amp isn't worth keeping. It's nothing more than a seriously over-hyped power booster that doesn't put out anywhere near the amount of power that it's advertised as having.
    2000 WS-6
    Quote Originally Posted by White Rascal
    yeah, just like every other factory system and a high percentage of aftermarket. its worth keeping to the extent that its cheaper than replacing everything just to replace the radio.
    OHIO Go Buckeyes!
    '07 Trailblazer LT
    In the long run a quality after-market system is the better way to go because it isn't self destructing all the time like the crappy factory electronics.
  1. Problem-New headunit w/Monsoon amp and speakers
    By hiberto in forum Stereo and Electronics
    Last Post: 07-05-2009, 07:57 PM
  2. Installing aftermarket speakers
    By Skitzo Gryphon in forum Stereo and Electronics
    Last Post: 12-10-2006, 12:05 PM
  3. Putting in aftermarket speakers
    By Skitzo Gryphon in forum Firebird / WS6
    Last Post: 12-09-2006, 09:43 PM
  4. Bypass aftermarket headunit amplifier for best sound quality?
    By ScrapMaker in forum Stereo and Electronics
    Last Post: 05-13-2006, 08:57 AM
  5. Aftermarket Headunit and stock amp
    By Tonys99RamAir in forum Stereo and Electronics
    Last Post: 11-07-2005, 08:57 AM
