    Slowride
    Guest
    Question Re Tool Needed For Slp Pulley Install
    I recently bought an SLP Pulley for my car. For installation it says that you need a GM Tool #J36660-A "torque angle". Do I really need this tool or can I just torque it down?
    Dreamin of a Paint Job... XtinKt's Avatar
    Alabama
    2000 WS6 Trans Am
    I just paid a machine shop to put it on for me. I didn't have the stuff to take it off with. cost me about 20-30 dollars. Save yourself the headache.
    Also a side note. I had problems with draining the battery by leaving my doors open for more than an hour. Usually if i was tuning, or detailin it.
    You will need to disconnect the batteyr when ever you are doing anything that requires you to keep the doors open.
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    Generally with a pulley install, you need a 6" 3 arm puller to pull the stock pulley off. It's a PITA but it can be done! You need a 1/2" drive breaker bar, 1 1/16" deep socket, and a torque wrench that can torque up to 250 ft lb's. The torque wrench is a must and if I were you, invest in an arp balancer bolt, it's longer than stock and it's help you a lot with getting it back on. If you want to do this all yourself and you need a write up, PM me and I'll send you one
    Alabama
    2000 WS6 Trans Am
    Take my advice and have some one put it on for you lmao
    Slowride
    Guest
    I See What You Mean About The Longer Bolt, That Would Have Helped. I Just Used A Rubber Mallet And Tapped It All The Way Around. I Looked For That Torque Angle Tool But Couldn't Find It So I Just Torqued It Down. I Didn't Have Any Leaks Or Wobbles So Guess I Did Alright. Thanks For Your Help!
    Feb 2008
    cincinnati,oh
    mystic teal
    2001 z28
    Redphoenix,
    i'd like to take you up on your offer for the write up on the slp underdrive pulley install. I've got a 2001 z28, a4 and i'm questioning how to hold the flywheel to be able to get the torque that is required in the instructions i've seen so far.
    I have the puller for the stock pulley and a torque wrench capable of the 240 foot pounds called for. If you could i would like to have your write up. I've looked on-line and in my haynes manual but the torque and the additional 140 degrees called for makes me think this may be a bit of the pita you mentioned.
    My e-mail is [email protected]
    thanks in advance for your help.
    Kdzrgrown
  1. Tool Review: Crank pulley removal
    By Slim80 in forum Tools
    Last Post: 10-12-2015, 10:48 AM
  2. For Sale: LS1 Crank Pulley Install Tool - $20 SHIPPED
    By 97ramsst in forum Parts For Sale / Trade
    Last Post: 06-06-2010, 03:25 PM
  3. Cam/pulley install question
    By jb3golf in forum General Help
    Last Post: 12-20-2009, 02:48 PM
  4. Underdrive pulley install question
    By KDZRGROWN in forum External Engine
    Last Post: 10-19-2008, 11:24 AM
  5. underdrive pulley install question
    By tx77015ls1 in forum General Help
    Last Post: 05-09-2006, 08:06 PM
