Results 1 to 18 of 18
Thread: Cam/pulley install question
12-19-2009, 05:21 PM #1
What up LS1's. This may be a stupid question BUT as long as I lined up the dots on the crank and cam gears/sprockets, does it matter that the crank is turning over some during the harmonic balancer install???? As long as the dots lined up prior to the pulley install, that's the important thing even if the crank is turned over a couple of times I'm thinking.........any clarification would be appreciated.......
12-19-2009, 06:10 PM #2Junior Member
- Jul 2007
- Lynchburg Va
- 1994 Z28
you can do it 2 ways dot to dot or both installed at 12 o' clock. but yes as long as its bolted up your fine man
12-19-2009, 07:53 PM #3
12-19-2009, 07:56 PM #4Junior Member
- Jul 2007
- Lynchburg Va
- 1994 Z28
no prob man, be SURE you use a new bolt too, my used and locktited bolt came out going down the road due to my lack of LS1 knowledge back when i did the install in my car haha i was too used to LT1s
12-19-2009, 08:01 PM #5
12-19-2009, 08:04 PM #6
OK ORION!! Where you at my brotha!! Anything to add to this info/question??? You know I'm always patiently waiting on your expertise!
12-19-2009, 08:05 PM #7Junior Member
- Jul 2007
- Lynchburg Va
- 1994 Z28
i got on it on the way back from a test drive in 2nd and let off at about 5k rpm and didnt upshift and i guess it was just too much for it haha...
12-19-2009, 08:32 PM #8
12-19-2009, 08:45 PM #9
As long as you have the cam gear bolt down, lined up directly with your crank gear dot... It doesnt matter if the pulley turns. This is mine, should look like it. Again, if the cam gear is bolted down, lined up dot to dot, the crank pulley can turn all it wants on install.
Build in progress...
12-19-2009, 09:18 PM #10
12-20-2009, 08:18 AM #11
yep, as long as it's dot to dot your good to go. Have you already got your pulley back on?
12-20-2009, 10:59 AM #12
Oh, how nice to hear from you ORION!!! I knew you would come through for me
.......Now to answer your Q.....No! The pulley sure is difficult to seat.....In fact it doesn't work to just get it on the crank ENOUGH to start threading the bolt.....It has to be pushed all the way onto the Crank fully in order to screw in the pulley bolt.....so I'm going to attempt to get this done today.(I rented a balancer installer from Auto Zone).... Additionally I read threads were many gus just heat up their pulley/balancer for 30 minutes and it slips right on.....Negative! This didn't work for me.........
12-20-2009, 11:19 AM #13
i feel your pain dude. i installed an underdrive fluid harmonic balancer and it was a total PITA to get on. i don't know the right way to install it, but i got out the dead knock mallet and went to town. lucky for me, i had just removed my sway bar the weekend prior. hopefully someone here can give us some advice as to proper installation so we all don't go around beating parts on our cars like i did.
12-20-2009, 11:28 AM #14
Right!!! Your on point there joedude....I mean there's so many little things one must know BEFORE taking on a project. I've certainly learned much over the past several weeks. Now, concerning the Balancer install, supposedly it is fairly straight forward with an install tool. So, now I'm going to start this challenge!lol I'll let everyone know how it went a couple hours from now. Thanks for the post......
12-20-2009, 11:32 AM #15Senior Member
- Oct 2008
- Coral Springs, Fl
Harmonic Balancer Pulley Installer
12-20-2009, 11:54 AM #16
I bought a length of metric all thread and cut a piece off about 18" long then I used 3 bolts and a bunch of washers to push the pulley on. You use 2 of the nuts on the end so you can hold the all thread and the nuts act like a jam stop then start adding washers and push the pulley with the 3rd nut. I heated mine in the oven and it went right on with no issues. Good luck.
12-20-2009, 12:58 PM #17
12-20-2009, 02:48 PM #18Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
Question: UD Pulley Install Tips
By Vertiviper in forum Firebird / WS6Replies: 5Last Post: 05-04-2010, 03:27 PM -
Underdrive pulley install question
By KDZRGROWN in forum External EngineReplies: 4Last Post: 10-19-2008, 11:24 AM -
Question Re Tool Needed For Slp Pulley Install
By Slowride in forum Firebird / WS6Replies: 5Last Post: 09-22-2008, 06:12 AM -
PS pulley install
By 98redbird in forum General HelpReplies: 2Last Post: 04-10-2008, 10:02 PM -
underdrive pulley install question
By tx77015ls1 in forum General HelpReplies: 4Last Post: 05-09-2006, 08:06 PM
Thanks for the reply. Just one less thing to worry about!!! Have a good X-mas.
going 80 down the freeway......
