    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    rear feels sloppy and unstable over bumps
    ive noticed that after changing out my sway bars (from stock to 1le) that my rear has been very unstable. if im on the highway, it bounces and sometimes feels like its going to throw me into the next lane. I do have the wrong size bushings in there right now, but am going to throw the stock one back in. ive only got 19mm bushings because summit sent the wrong ones. here are my mods:
    spohn chassis mounted TA -2 pinion angle
    relocation brackets
    poly lcas on lowest hole
    9" with tru trac
    bilstein hds
    stock springs
    1le swaybars (front and rear)
    I think thats it. If its the bushings, im going back to the stock one next week anyways. Ive also considered putting my lca's in the stock location to help with my regular driving and turning. any other ideas?
    __________________
    Could be the bushings as they won't be working right.
    You can order just bushings from the sponcers to this site.
    Replace them first and report back to us if that was the problem or not.
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    put back the stock rear swaybar and i'm sure the car will be better.
    keep the front 1le one, though.
    the rear is probably too stiff.
    Eugenio_SS
    Aug 2003
    Honolulu HI
    thanks. thats what ive been thinking. ill do it this weekend or sometime next week if i can.
    Jun 2002
    Montreal, CANADA
    triple-black
    have you tried it ?
    Aug 2003
    Honolulu HI
    not yet. i need to go get my stock bar from my friends shop this week.
  1. Oil Pressure, unstable after A/C Compressor install.
    By FiretoFlames in forum General Help
    Last Post: 09-27-2014, 03:45 PM
  2. T56 Noise - Sounds Like Sloppy U Joint
    By YellaGoat in forum Manual Transmission
    Last Post: 08-10-2014, 01:11 PM
  3. right rear clunking over bumps.bearings?
    By Leeroyws6 in forum General Help
    Last Post: 07-04-2010, 03:24 PM
  4. I HATE sloppy messes!
    By Neo in forum Almost Anything Goes
    Last Post: 08-07-2007, 09:50 PM
  5. sloppy noise--
    By CYCLONE GREY GTO in forum GTO
    Last Post: 06-10-2007, 11:06 AM
